Hp envy VBUS50 LA-9511P REV 1.0 DUMP NEED
  • cacla
    • Apr 2015
    • 442
    hi there i need dump for this board LA-9511P REV 1.0
    I need main and EC bios
  • Habble7
    by Habble7
    Suspected Cause:
    Troubleshooting Attempts:
    05-22-2025, 07:28 AM
  • robgerr
    Asus K3500P Main (X7400PC R2.2) Bios Dump Reques
    by robgerr
    Good morning forum, I'm trying different bios to try to resurrect this machine, with all the bios tried the machine turns on, the fans turn but the screen is black. I tried to download the correct bios from the Asus website (x3500PC by reading the QRCODE from the motherboard) but this is a PFAT AMI, I managed to decrypt it but I get several files and rebuilding it is very laborious, I tried with the uefi tool to extract only the main bios and cut the decrypted one and rebuild it in hex but it doesn't work the same. Wondering if anyone has a dump for this main board. I thank you.
    Attach...
    11-17-2023, 09:52 AM
  • Kenzi
    Cannot modify HP Envy 15 ep-00008na BIOS
    by Kenzi
    I'm trying to modify my BIOS to unlock the advanced menus and unlock the processor power limits. The first thing I have tried is reading the BIOS from the laptop and opening it up in amibcp, and changing the advanced menu to User. However, no matter what tiny change I make to the BIOS, when I flash it back to the laptop with a programmer it says there is corruption and the BIOS needs to be recovered.
    I've also tried rolling back the BIOS to an older version. I made the mistake of updating to the latest version and now I cannot even edit the CFG and OC...
    11-09-2023, 05:22 AM
  • DynaxSC
    by DynaxSC
    11-17-2023, 10:56 AM
  • cekcons
    g1 assassin Rev 1 bios dump - main and backup needed
    by cekcons
    main and backup ic dead so i cant post corrupt bios cause its 01 all over.
    thanks
    01-23-2024, 03:26 AM
