Benq FP 767-12 goes off after approx 30min
+ More Options
Posts
  • dvorav
    • Oct 2008
    • 43
    Greetings,
    I have recently got BenQ FP 767-12 panel.
    It has strange fault. If I connect it to the DVI intervace via VGA reduction. It is qite fine, no turning off even after a lot of hours. But if connect it to the analogue VGA inerface, it periodically turns off itself (no picture but power button shining). Then after while beeing off, it is possible to turn in on again for a while.
    It seems to be some kind of signal problem. I'd like to know some proffesional opinions.
  • seppde
    Benq Zowie XL2540K / Power board failure / 6Pin-SOP-Chip identification
    by seppde
    I've got a Benq power board of a XL2540K monitor which suffered from a power cut and is since defective / won't turn on. It's got obvious defects, some blown resistors, some burning around the drain pin of a MOSFET...
    ... and some 6-pin IC I struggle identifying, that is driving said MOSFET.
    The IC is labeled as IC601, so someone with a circuit schematic could probably identify it really quick, unfortunately I can't find the schematics.
    In other power boards of Benq for which I did find the schematics, IC601 is an 8-pin NCP1200 PWM controller - I suppose...
    02-09-2024, 05:19 AM
  • AJ847.63e
    BenQ TH681 Originally overheating now wont fire the lamp - Colour wheel not starting
    by AJ847.63e
    Hi All.
    Does anyone have any reference materials or something I can use to try troubleshooting a BenQ TH681? Google unfortunately has turned up zip. I did find a service manual for a W series BenQ but that is pretty much useless, it's more a glorified user manual. A list of voltages would be great as I suspect my mainboard is faulty, the colour wheel voltage is not dipping like it should.
    The one I am troubleshooting now was originally overheating after a lamp replacement. It originally would take 2 minutes or so for it to shut off and blink the temp and lamp lights...
    09-18-2023, 06:42 PM
  • ChatBTC
    Benq EX3501R
    by ChatBTC
    Hi!
    I am new to this site, and found it via LLM ChatGPT.
    I got a BenQ Ex3501R monitor which i have had for a while now, it works pretty good until recently, it struggles to turn on, i can see the purple welcome screen is shown for a brief time before it vanish again, usually it stays on for a couple of seconds before the main computer screen is shown, but image is still kept black, before i just had to turn it off and on a few times and that would leave it on, but now it takes ever longer to stabilize the image on the screen, ocasionally i can see the computer desktop...
    01-24-2025, 08:49 PM
    BenQ JoyBook S52 S53 Laptop Schematic
    Quanta ED3...
    11-01-2024, 02:03 PM
    BenQ S72 Laptop Schematic
    Inventec Grasshopper Rev 3.0...
    11-01-2024, 07:23 AM
