Samsung S34E790C just a few vertical lines
  • KomoK
    • Jul 2017
    Hi!
    I have a 34" curved Monitor, just out of warranty.
    Here are the symptoms:
    It had like 14 different colored thin lines, dotted.
    I replaced the TCON board with one on ebay.
    I get the same thing now after replacement, but with 6 lines. I went ahead and put back my old one, and now I get 6 lines on that guy.
    Is this a main board problem, or tab / panel issue?
    Thanks in advanced! This site rocks.
    Koz
  • Afickgenius
    • Jan 2019
    • 12
    • Malaysia
    Re: Samsung S34E790C just a few vertical lines
    wow no body responding to ur question..
    • tehmatix
      • Nov 2012
      • 177
      Have you tried to make some pressure on the flexy at junction with pcb or glass/screen, too see if is any improvement
      • Falki
        Colorful LCD Vertical Lines on Samsung ue55es8090
        by Falki
        Hello there, ive recently found an older 55inch Samsung SmartTV.
        Sadly it has vertical lines at the left and one line in the middle-right.
        I have already tested out the connections and have looked at the soldered ribbons of the LCD panel to see if some contacts got loose by pushing them a bit but with no success.
        I have factory resetted the TV as well but also with no luck.
        I am afraid that it is indeed a LCD Panel issue but there are NO scratches or any impact-marks..
        A similar issue has been posted as well but also with no actual response ...
        08-12-2025, 04:19 AM
      • Stanley1843
        Screen Display Vertical Multicolor Lines
        by Stanley1843
        Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
        06-29-2024, 11:54 AM
      • x_orange90_x
        Samsung UN46C8000XFXZA vertical bars/horizontal lines
        by x_orange90_x
        I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
        The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
        09-04-2023, 12:09 PM
      • polaro
        Thin stable coloured vertical lines on Samsung UN65NU6900FXZC come and go
        by polaro
        Greetings,
        I've bought a used Samsung UN65NU6900FXZC LED TV. It worked fine for some time and then developed, at first, a single very thin (1 pixel) vertical stable blue line, from top to bottom, close to the left edge of the screen. Now it's 3 lines on the left. When I connect HDMI sources the number of the thin lines grow. After disconnecting and cold discharging I am back to 2 lines. The lines disappear at a rate of 15-20 minutes per line. So it does not look like a damaged LED panel. Any advice? Thanks...
        08-27-2022, 08:46 AM
        09-07-2024, 05:50 AM
