Help with Apricot-Pc video and disk drive issue.
+ More Options
Posts
  • roadrash
    • Oct 2015
    • 490
    • U.K.
    I have a couple of vintage Apricot Pc's that I have got to work after rebuilding their PSU's which as usual blew the Rifa filter caps etc. One of them was working great and the display output on its tiny dedicated green screen monitor nice and sharp. After a while I noticed that it had got some interference on the display which is not the fault of the monitor as it tests fine on the other Apricot that's working and swapping PSU's over makes no differnce. So it must be a component failing on the motherboard. The other Apricot has a good display output but wont read properly from any of the known good disk drives. I have not yet recapped the motherboards and this will be my next job now I know its not a monitor or faulty disk drive.
    Is there anything in particular other than the caps, I should be paying attention to re the video & disk drive issue on these motherboards?
    Pictures attached.
  • R_J
    • 9535
    Re: Help with Apricot-Pc video and disk drive issue.
    The first cap I would suspect for the video problem would be C3 100uf located on the base of TR1 (next to the video connector) Then I would change the caps off the PSU Connector CM, CE
    • roadrash
      • Oct 2015
      • 490
      • U.K.
      I have replaced some of the caps one one of the apricots including the ones you mentioned and after giving it a test, the video output is still messed up but now the disk drives which were working are no longer reading disks although are are seeking.
      I have been trying to check each caps connection one a a time using the other untouched board as a guide. Its proving very time consuming as its obviously a multilayer pcb as some of the solder joints don't go to any tracks and just appear to go nowhere. I have managed to trace these and found them connecting to a component nearby which proves they are connecting via a track hidden inside the pcb. There are some that after much time now, I cannot trace where they are going to and without a schematic (there are none anywhere) its near on impossible.
      obviously one of the caps I replaced is not connecting properly as surely using a 16v cap instead of a 10v cap wouldn't affect the disk drive reading would it.
      Ive still yet to cure the video issue as well.
      • R_J
        • 9535
        Is'nt this the manual with schematic for that model? have a close look at the leads of the capacitors you removed and see if any of the feed-thru's came out with the cap. on a multilayerboard like these it may be better to cut the leads at the cap body and attach the new cap to the original leads.
        • roadrash
          • Oct 2015
          • 490
          • U.K.
          Thanks for that info. Did eventually trace where all those caps connected to and obviously they all have a connection. So thats makes me wonder why the disk drive is no longer reading a floppy if all I have done is change these caps for the same capacitance value except they are 16v and not 10v. Surely this wouldn't cause this would it?. Nice tip on removing those caps. They actually came out easy and didn't pull the feed thru's out. I know what you mean though, ive done that before when a components a tight fit coming out.
          nice hand written schematic.
          • R_J
            • 9535
            I have no idea what happened to the drive not reading, uping the cap voltage will not make any difference. does it give a drive error code? not spin? seek but not finding the media?
            • roadrash
              • Oct 2015
              • 490
              • U.K.
              Not sure myself why it should stop reading the disk. When its turned on the display comes on and the disk drive moves its head across the disk surface as normal but then doesn't start reading and booting the disk as it used to do before I changed the caps. If its not a voltage issue with those caps all I can do is follow the schematic cap by cap that I replaced and check they are all connecting to all the right places.. cheers thanks
              • roadrash
                • Oct 2015
                • 490
                • U.K.
                OMG, what a schematic! I am no expert but this schematic is hard to follow and doesn't show all the electro caps there are and its very hard to follow.
                Caps don't have a unique ID and 4 or more caps having the same ID and can located close by as well as well as other area's all over the pcb. For example there are 4 caps near the 8x4 rows of memory chips all with the ID of "CE" (3 coloured grey & one black all 68uf 10v) and are not even shown on the schematic anywhere near the ram chips but there are other caps marked as CE in other areas as well. This is proving a real challenge and will need some help here.
                • roadrash
                  • Oct 2015
                  • 490
                  • U.K.
                  looks like i may have found the fault. I removed all the caps i put in and desoldeted and checked all the contact pads and one susicious looking one when viewed under a magnifying glass revealed what you see in the attached picture. I couldnt belielve how close that track was to the pad and remember that pic is magnified. its litterally only about .2 mm away. I think its best to tun a link wire across instead of repairing and reusing that track
                  • R_J
                    • 9535
                    It looks like the line is the DCDB (data carrier detect B) between the z80 pin 22 to ic6 pin 16 I did't trace it any further but it may have told the system to look at connector C instead of the ide drive, just a guess,
                    IC6 driver chip for controling inputs/outputs/ on Centronics parallel port.
                    running a thin wire between the 2 points should be fine.
                    • roadrash
                      • Oct 2015
                      • 490
                      • U.K.
                      that makes perfect sense and now hopefuly the disk dtive wil read disks again now
                      • reformatt
                        Intel iMacs, 3rd party SSD failures and Fusion setups
                        by reformatt
                        I thought I'd throw out some of my personal experiences in the last 12 months with Intel iMacs, 2.5" SATA SSD drives and Fusion drive data recoveries.
                        As a backgrounder, Apple never fitted a 2.5" SSD's to these iMacs. Apple's SSD option was a system of 32GB NVMe blade drive (NGFF connector) and Seagate 1TB 2.5" HDD, married together in software to become a Fusion drive. Non Fusion systems have just the 1TB Seagate HDD.
                        So, the most common reason an iMac comes across my bench is because it's either ridiculously slow, or it fails to boot at all. The most...
                        12-18-2024, 10:34 PM
                      • Nicktronic
                        Philips 75PFL5704/F7 A Video Issue
                        by Nicktronic
                        Hey everybody, got a strange one here.
                        The TV will display the Home Screen, Menus, Netflix Home Screen, YouTube home screen with preview tiles, etc, without issue. As soon as I try to play video (streaming or from any of the HDMI inputs), all I get is audio and and blank screen. It's like the video is not being processed. So I ordered a replacement main board. I can now play video from streaming sources but the video from HDMI sources is all green (kinda like photo negatives but all green) and the audio does not work. Is it possible the main board I ordered is also failing?? I can't...
                        10-31-2023, 05:43 AM
                      • DynaxSC
                        ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
                        by DynaxSC
                        I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
                        Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
                        Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
                        The behaviour is also really very strange, i.e.:
                        • The disk shows always up in BIOS - so it is recognized, so far so good
                        • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
                        02-23-2025, 01:33 PM
                      • bbenalmadena
                        UX461UA no post, fix
                        by bbenalmadena
                        Hi, been banging my head two days with a UX461UA Zenbook Asus that will not post. Laptop looks ok, all voltages looks nominal, CPU gets hot, even fan kicks in when it gets hot, I removed the m2 drive and tried several things, I thought it was a bios issue, I even registered here to try flashing with some BIOSes but the problem still was the same, no POST
                        At last I decided to check the disk drive to see if any backup can be done and then I realized that the disk drive was broken, I thought what are the odds that the motherboard and the drive at the same time? So I just plug another...
                        09-05-2024, 02:18 AM
                      • eccerr0r
                        It's 2025: do you know where your 5¼" floppy drives are?
                        by eccerr0r
                        Oh wow.
                        As in the other thread I was trying to revive/re-bootstrap an old Apple IIe and wasn't successful reading or writing any disk. Both drives behave similarly.
                        Then I was wondering, what about my PC floppy drives? I have a HH 5¼" HD drive and a combo 5¼+3½ drive. I tried formatting the disk that wouldn't work in the Apple and it didn't work in the PC either!
                        Then I tried a HD 5.25 disk ... it won't even touch the disk either! Just like the Apple DD disk, "Not Ready!"
                        Weird. Seems the PC drive is having trouble clamping...
                        07-07-2025, 12:49 AM
