BenQ FP757 monitor problem
  • speedfreak_kc
    • Oct 2008
    When I turn it on I get a quick blink of blue light from the pwr button. It does not show any picture. Does anyone have any ideas?
  • Krankshaft
    • Jan 2007
    • 2328
    Re: BenQ FP757 monitor problem
    Check for bulged caps on the inverter board if you don't find bad caps check the c5707 transistors one of them is probably shorted.
    • Askic
      Problem with monitor DS-D5022QE-B
      by Askic
      Hello to all,
      I have a problem with monitor that is delivered together with CCTV system.
      The monitor appears to be completely dead, there is no LED power diode and it doesn't react to pressed power button.
      I have disconnect display and check many components on the power supply part of the board. There is no anything obvious and monitor is about 3 years old. There are no bulged caps. When measuring voltages on the output connector to VGA board I can measure stable 14.5 V on 12V pins and stable 5.07V on 5V pins. So I assumed that this part of the board is OK....
      05-31-2023, 03:14 AM
    • CptChronic
      Samsung LU32J590UQUXEN Monitor display problem
      by CptChronic
      I have an intermittent display problem with my monitor, when I plug in the HDMI cable to my (or any) laptop, you see the connection screen shrink on the laptop as it usually would before displaying on the monitor but 95% of the time the monitor display stays black.
      Before it cut out all together, tapping the monitor control button a fair few times would make the screen display, and everything work fine.
      But now it never does it. Not sure what's going on, hoping someone can help. I'm capable of stripping the thing down and soldering in new parts if needed, or programming...
      04-24-2023, 04:33 PM
    • tmhobadcap
      LG 24MP56HQ-P Monitor Backlight problem?
      by tmhobadcap
      I have a few successful experience in fixing tv backlight problem. But for monitor, I have no experience. However, I think they are more or less the same. Am I correct?
      Recently, I got the captioned monitor and the owner said it could not be turned on. I open it up and found that one of the SMT capacitors seemed to be bad. I replaced it as well as the other one. The monitor still could not be turned on.
      I found the power indicator is on. When I shine a flashlight on the screen, I can see the image. Therefore, I think it is with backlight problem. I took out the led strip....
      10-13-2021, 01:52 PM
    • tmhobadcap
      by tmhobadcap
      10-12-2021, 01:43 PM
    • bembeno
      Benq T902DHA monitor turns off after 5 minutes
      by bembeno
      Benq T902DHA monitor when press power button its work good but turns off after 5 minutes ( power led off ) just when i plug any display source
      07-27-2024, 09:55 AM
