Dell inspiron N7110 LCD no back light
  • bigsam731
    • Oct 2016
    • 27
    • usa
    #41
    Re: Dell inspiron N7110 LCD no back light
    OK. Ill hold off on it and use it as is for now till Mr. Budm can figure something out. Please let me know if you need me to do more testing or anything else. I really appreciate you guys help.
    • meritosari
      • Oct 2010
      • 774
      • Indonesia
      #42
      I believe this case will end with Happy ending.
        Please see post 40.
        • bigsam731
          • Oct 2016
          • 27
          • usa
          #44
          I did disconnect the wire going back to pin 18 from pin 36. I just connected it to pin 2 without a resistor. what does S3, on pg. 2 of the schematics, have to do with LCDVCC?
            That page is not truely clear to me if the S* STATESare the sequencing of the power or what.
            I would suggest to use resistor between pin 2 and pin 36, when pin 2 3.3VDC is switched off then the backlights will be off at the same time, and when the pin 2 is switched on then you will have backlights. So basically we are using the switched pin 2 3.3V to turn on and off the backlights.
            You can verify that pin 2 is a switched power by checking to see if 3.3V is NOT present when PC is off.
            • bigsam731
              • Oct 2016
              • 27
              • usa
              #46
              I will double check and make sure that pin 2 has switched power. Laptop should be plugged into power or the battery and in the off state when I do the test correct?
              Also, why do I need a resistor between the two pins? And what type of resister should I use? Please forgive my ignorance on the last two questions, I just want to learn.
                'make sure that pin 2 has switched power. Laptop should be plugged into power or the battery and in the off state when I do the test correct?' Correct.
                The resistor is in the circuit to limit the current in case there shorted circuit between pin 36 and GND when something goes wrong.
                470 Ohms 1/8W or 1/4W will do.
                • bigsam731
                  • Oct 2016
                  • 27
                  • usa
                  #48
                  Pin 2 is switched. I checked the voltage while the laptop in in the off state and got 2.1MV. and will install the resistor once I receive the order.
                    DELL Inspiron 3671 Inspiron 3000 i3-9100 Specification for Upgrade or Repair
                    This specification for the DELL Inspiron 3671 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3671 boardview and Inspiron 3671 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                    09-12-2024, 03:36 PM
                    DELL Inspiron 5680 Inspiron 5000 i5-8400 Specification for Upgrade or Repair
                    This specification for the DELL Inspiron 5680 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 5680 boardview and Inspiron 5680 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                    09-12-2024, 03:30 PM
                    DELL Inspiron 3668 Inspiron 3000 i5-7400 Specification for Upgrade or Repair
                    This specification for the DELL Inspiron 3668 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3668 boardview and Inspiron 3668 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                    09-12-2024, 03:28 PM
                    DELL Inspiron 5680 Inspiron 5000 i3-8100 Specification for Upgrade or Repair
