Samsung T240HD Cycling colors
  • CESMOtacon
    • Aug 2016
    My T240HD is acting strange; when I turn it on it cycles white, grey, black, multicolor, repeat. I've included a video: https://goo.gl/photos/mDCio5R4hqw53pcH7
    I'm planning to open it up and see if it is a bad capacitor. Does anyone have any other ideas?
    Re: Samsung T240HD Cycling colors
    Is it connected to running PC or running Video sources?
    Nothing in the owner manual that I can see regarding to this pixels test mode.
    • CESMOtacon
      • Aug 2016
      It was running off of an amazon fire TV stick from the HDMI port. This behavior is not the normal display it shows if no video source is connected.
      • CESMOtacon
        • Aug 2016
        Sorry for double reply, but i've resolved my issue. I think it was a loose connector. I took the TV apart, took out both boards and inspected them. I didn't see any popped caps or burnt looking IC's so I put it all back together and it's now working.
          09-07-2024, 05:50 AM
        • high-tech
          Samsung UN55F7050AFXZA ver. TD01 power cycling
          by high-tech
          Hello everybody, I could use some help on this one... It's got me guessing...
          I took pictures of all the boards and the pin out of the connector on the power supply that goes to the main board... I measured all the pins in relation to chassis ground, here are the result.
          (B13v)1. 12.7 volts cycling (Vamp) 2. 12.7 volts cycling
          (B13v)3. 12.7 volts cycling (PWM5) 4. 1.0 volts cycling
          (OD_LE)5. 2.8 volts cycling (PWM4) 6. 0.9 volts cycling
          (OD_ON)7. 2.8 volts cycling (PWM3) 8. 0.9 volts cycling
          9. ground (PWM2) 10. 0.9 volts cycling...
          09-15-2020, 03:39 PM
          09-06-2024, 11:40 PM
          09-06-2024, 08:40 PM
