Viewsonic 2235WM monitor will not turn on
  • engineer350
    • Jul 2016
    I have a Viewsonic Monitor 2235WM, the monitor went off, I replaced the capacitors as outlined on this site but it still will not work.
    I have checked the 14-volt. 5-volt and 3.3 volt on the card DAC-19M009 Rev 01a at the plug that connects it to the other card A170E2-E03-H-S6, all these voltages are present on the Pin-8, Pin and 10 and Pin-15, but when I press the on switch the on LED does not light and the monitor remains dead.
    I have checked the fuses on both cards they are all OK, can anyone help please
  • wattage
    by wattage
    Hello Badcaps Community,
    07-13-2025, 04:41 PM
  • ant3202
    HP 27es - LED monitor - Monitor Flashing On - Off
    by ant3202
    Hi Everyone
    Lately I am experiencing the deja-vu incident on one of the led monitor like this.
    https://www.badcaps.net/forum/troubl...lashing-on-off
    The monitor is HP 27es LED Monitor
    https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
    The monitor will randomly blackout and display no signal and will recover again.
    Sometimes need to power and off again to restore the display but...
    03-20-2025, 07:30 PM
  • pajdek
    Lenovo Y700-17ISK turn on and off
    by pajdek
    Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
    09-20-2023, 02:49 AM
  • sew333
    Pc shutdown, monitor flickered with no signal after 10 seconds
    by sew333
    My pc:
    10850K stock 4800mhz stock Kraken X73 good temps
    2x16 GB DDR4 GSKILL 3000mhz XMP
    Seasonic Tx-850 Ultra Titanium
    Gigabyte Rtx 3090 Gaming OC
    Aorus Z490 Pro Gaming
    1 TB SSD
    4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
    Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
    Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
    Power...
    02-22-2022, 10:27 AM
  • matthewmcconaughey
    I need help with my friend Sony GDM-FW900 24” CRT
    by matthewmcconaughey
    Hello, Badcaps is my last resort. I am the first owner of the monitor. I reached almost every repair store in my area, but no one even wanted to hear about troubleshooting an old CRT monitor. At this point, I have been trying to figure it out by myself, but I have no idea where to start or look for.
    I wish to know how to think and locate a failing component. I will put all my efforts to learn and contribute.
    1. It started with a bright and greenish picture upon starting a cold monitor.
    2. About 2 years ago, only on the cold boot, the screen started to occasionally flash with
    05-16-2023, 03:15 PM
