APEC AP4511GM MOSFET -- where to get?
  • truename
    • Feb 2008
    • 6
    Guys/Gals, I need to replace a failed APEC 4511GM MOSFET (http://www.a-power.com.tw/ProductDetails.asp?M_ID=293).
    Any ideas on where to get either the original part or its sub?
    This is for a MAG 700P monitor with a Lien Chang board in it.
    Thanks for your help!
  • truename
    • Feb 2008
    • 6
    Re: APEC AP4511GM MOSFET -- where to get?
    Found this part, datasheet parameters look very similar except lower current on P-channel: APEC's unit is rated at 7 and 6.1 amps for N and P channels, the IR's unit is rated at 6.5 and 4.9 amps respectively. Do you think it will still work?
    (http://www.newark.com/jsp/search/pro...C-GB100000001).
    • Jane
      How do you test MOSFET in laptops ?
      by Jane
      I tried to use this method:
      Testing an N-channel MOSFET:
      Step 1: Discharge the Gate (turn off the MOSFET)
      Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
      Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
      Step 2: Charge the Gate (turn on the MOSFET)
      Now, place the red probe on the Gate (G) and the black probe on the
      09-27-2024, 03:31 AM
    • Nooy
      VGA MOSfet permanently shorted and loss of MOSfet pad
      by Nooy
      Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
      I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
      02-14-2024, 02:26 AM
    • redbaron1007
      Help identifying mosfet on Razer Blade RZ09 (CH570_MB_NT)
      by redbaron1007
      I have a Razer laptop (RZ09 MB# CH570_MB_NT) that has a shorted mosfet marked BND M03 E067 that I'm unable to find anywhere online. Does anyone either know what the part number is for this mosfet or have a schematic I can find it in?
      Backstory on the whole thing the laptop was plugged into a lamp at a hotel. The lamp got unplugged while it was charging and now the system won't power on anymore. I found the caps around this mosfet shorted and when I injected voltage into the caps the mosfet got hot and my bench psu was pulling 5A. Pretty sure this is all that's wrong with the laptop...
      09-09-2025, 11:10 AM
      Acer Swift SF314-511-700P Notebook 3 Specification for Upgrade or Repair
      This specification for the Acer Swift SF314-511-700P Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SF314-511-700P boardview and SF314-511-700P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
      09-07-2024, 12:10 AM
    • AppleLover123
      Asus X712EA 3 volts after the first mosfet
      by AppleLover123
      Hey guys,
      i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
      I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
      Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
      I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
      Now i thought something...
      12-15-2024, 07:49 AM
