Bad caps in ViewSonic VP930b?
    I have an LCD whose power will not turn on. There is a cricket sound coming from the transformer on the power supply.
    I attached two images of the caps on the board, they are made by CapXon
    I apologize for the blurry pictures, I can take better pictures if needed.
    Info on the caps
    First Image:
    100uF 400v
    Second Image:
    As seen in the picture
    * 1
    2 3
    * 4
    5 6
    1&4 = 220uF 25v
    2&3 = 470uF 35V
    5&6 = 1000uF 16V
    Is the cricket sound caused by bad caps?
    What caps should I replace the current ones with?
    sorry for second thread, nobody was replying in the other forum
    Re: Bad caps in ViewSonic VP930b?
    panasonic fc is a good choice in there.
    better at taking heat than fm.
      No need to double post I left a reply in your first thread:
      https://www.badcaps.net/forum/showthread.php?t=5537
        Thank you for your help. Here is the list of parts I found, how does it look?
        I could not find the 100uF 400v in the FC series..
        100uF 400v
        http://search.digikey.com/scripts/Dk...name=P13670-ND
        220uF 25v
        http://search.digikey.com/scripts/Dk...name=P10271-ND
        470uF 35V
        http://search.digikey.com/scripts/Dk...EU-FC1V471B-ND
        1000uF 16V
        http://search.digikey.com/scripts/Dk...name=P10253-ND
          the 100uF 400v only came in bulk
          how is this to replace it?
          http://search.digikey.com/scripts/Dk...me=493-1234-ND
            I replaced all of the caps and it works. Thank you all for your help.
              Are these caps easy to access, since no one supplied the schematic. Or, is a schematic necessary?
                Can you please give me the specific links to the digikey caps and how many of each? I would greatly appreciate it - I'm going to attempt the repair.
                  Manufacturers sometimes make board changes so it is always best to make your own parts list. If you follow PlainBill's instructions, you can order Panasonic FM or FR caps.
                  https://www.badcaps.net/forum/showpo...33&postcount=2
                  --- begin sig file ---
                  --- end sig file ---
