HP w2207 - which caps?
  • Sneps
    • Apr 2016
    • Italy
    Hey guys, i need to know which caps are soldered on the w2207 to replace them as some of them are blown. I dont want to open the device until i got the replacement parts as i get it to work by heaten the monitor up for a bit before powering it on. Thank you very much for your help
  • 1supertech
    • Apr 2012
    • 384
    Re: HP w2207 - which caps?
    http://www.amazon.com/Repair-W2207-M.../dp/B0088IAXJY
    • Sneps
      • Apr 2016
      • Italy
      Thank you, but i already found these kind of repair kits. But as i want to order the caps separatly and i dont live in america, i need to know exactly the specs of caps that are used on the monitor or in this repair kit
      • 1supertech
        • Apr 2012
        • 384
        To be able to order each cap separately you will have to open the monitor
        Farnell is in Italy
        http://it.farnell.com/?pffref=http:/...417.1460561246
        • Sneps
          • Apr 2016
          • Italy
          I.know that i can look inside the monitor. But as i wrote before, i dont want to do it before i get the replacement caps.
          Thats why i opened the thread. To ask if someone knows which caps are soldered in the monitor so that i can order that without opening the monitor before.
          What can i do with farnell?
            http://lcdalternatives.com/HP-W2207-...-P1660299.aspx
            http://www.super-laptop-parts.com/ge...3-p-32107.html
            There are more then one version of the board used in the W2207, so if you not going to open it up then you are not going to know which board you have in your monitor.
            • black6host
              Replacement caps for Samson Resolv studio monitor 65A Amp board.
              by black6host
              Good day!
              I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
              I'm going to replace the caps and I'll be the first...
              02-06-2024, 08:22 PM
              by momaka
              03-15-2023, 10:17 PM
              by momaka
              03-12-2025, 03:42 PM
              Westinghouse L2210NW LCD monitor - bad caps repair
              by momaka
              Here's another LCD monitor repair: Westinghouse L2210NW.
              Quick specs: 22” CCFL backlit LCD, 1680x1050 max resolution (16:10 aspect ratio)
              I got it with a bunch of desktops PCs from a repair shop that was trying to free up space a few years ago. It seemed like a cheap monitor, so I didn't really care that much at first when I picked it up (and indeed it is, picture-wise.) But hey, free is free, so I can't complain. Moreover, it looked clean and the screen didn't have any significant scratches or blemishes.
              Pictures of the monitor outside/case after a brief...
              01-11-2021, 01:14 AM
            • eryjus
              by eryjus
              05-10-2023, 11:21 AM
