Acer AL1715 AUO Panel Problem
  • muther_trucker
    • Jun 2008
    • 7
    The Monitor: Acer AL1715 (specific model: Acer AL1715t AUO Panel)
    The Problem: Plugged power supply + vga cable in, turned the monitor on; I get the Acer logo displaying for what seems like quarter of a second! (my other acer monitor [AL1714] displays it for about 2 seconds when powered on). Then the screen flickers bright white, then black, then displays the extended desktop for about half a second, then goes back to black, might flicker white again before staying on black. It will then go to standby after several seconds.
    Also, I can't at any point access the menu on the monitor, even though I can press the "auto" button, and I notice the screen go though its auto calibration for a second.
    Causes?
    • NOT the graphics card
    • Don't think it's the VGA cable, it DOES display the image (even though its a split second)
    • NOT the power supply, definatly supplies power to the monitor
    • Could it be the Capacitors? - I've seen this problem before
    • Or some other issue? - I really don't know
    First off, I'm going to get a short video clip of this tomorrow morning, just to explain further whats going on. =
    Video of my Acer AL1715 playing up. NOTE: First screen is an Acer AL1714 working as it should.
    Second, I've taken it apart and checked out for shorts, doesn't seem like any there, and all the connections are in good order.
    If anyone has anything that could help, please do!
    I'm going to check the capacitors for damage, hopefully it might highlight any problems.
  • dood
    Deputy dood
    • Mar 2004
    • 2462
    Re: Acer AL1715 AUO Panel Problem
    Is it still under warranty? I've seen issues like this with these panels. However, having a 3 year warranty, I've never had to fix one on my own. Usually they come back with the controller board replaced, according to the paperwork.
    Ludicrous gibs!
    • muther_trucker
      • Jun 2008
      • 7
      Well, the monitor was a purchase off ebay (where it was shown to be working), but I've since had my money refunded
      But I'd still like to get this monitor working; I guess it's got no warrenty now.
      • dood
        Deputy dood
        • Mar 2004
        • 2462
        You could always give it a shot with Acer... see if they'll fix it just based off the serial #. https://secure2.tx.acer.com/FixMyAcer3/FixMyAcer.aspx
        Ludicrous gibs!
        • muther_trucker
          • Jun 2008
          • 7
          I'm actually having trouble with it recognising my serial number
          • muther_trucker
            • Jun 2008
            • 7
            I suppose it doesn't help that I'm actually in the UK. I suppose I should have mentioned that beforehand.
            • muther_trucker
              • Jun 2008
              • 7
              Just an update: Phoned Acer Tech Support (UK). They said I need to get the original receipt for the product, and the details that the monitor is registered in.
              After that I'm going to phone in and ask about repair. Hopefully the warrenty is still valid!
              • dood
                Deputy dood
                • Mar 2004
                • 2462
                I don't remember having to jump through that many hoops here in the US. Then again, they were retail purchases, not eBay buys. So maybe I don't remember it because it just wasn't any hassle.
                Ludicrous gibs!
                • muther_trucker
                  • Jun 2008
                  • 7
                  Typical. The person on eBay doesn't have the receipt, and don't know who it was originally registered too.
                  • elbtax
                    • Apr 2008
                    • 59
                    Check for "dry" solder joints. Sometimes this will cause the above.
                    • muther_trucker
                      • Jun 2008
                      • 7
                      Okay thank you for your input. I have gone over the boards, and can't really find anything wrong to my eye
                      The photos of the boards are attached...
                      • maralexbar
                        How to force Acer Aspire Series to bootup BIOS/UEFI on external Monitor?
                        by maralexbar
                        I ask this question in general as there are many Acer Aspire models with UEFI Insyde BIOS that do not boot to the BIOS on an external monitor (VGA, HDMI, etc) showing only the Internal LCD (LVDS, eDP etc).
                        It's a pain to work on Acer notebooks with a broken screen and not being able to access the BIOS using an external monitor.
                        If anyone knows how to force the external monitor as primary for Notebooks of those models
                        11-02-2024, 09:18 AM
                      • keepread
                        Dell monitor PSU vs Dell laptop PSU
                        by keepread
                        Hi there!
                        Someone gave me their old monitor, it's Dell S2715ht.
                        The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
                        Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
                        10-30-2025, 04:45 PM
                        09-06-2024, 05:27 AM
                      • ahmarzo
                        Acer TMX314-51 laptop battery problem
                        by ahmarzo
                        I have acer laptop tmx314-51 with part no 6050A3020501.
                        The laptop is working fine on adapter and battery is also charging and when adapter is disconnected in on state the laptop gives backup on battery and gives good backup.
                        But when laptop is powered on through battery only the laptop does not power on and there is 0 voltage on battery connector.
                        I have not not tried another battery as it is not available locally could this be a battery problem.have checked discharging mosfet and there is no shorting to ground on any pin of battery connector.
                        The schematic is not available...
                        04-11-2025, 09:14 AM
                      • fmajbour
                        Acer Nitro 5 model A515-51 keyboard problem
                        by fmajbour
                        I have ACER Nitro 5 model AN515-51 main board model LA-E911P Rev 1A after replacing the mainboard keyboard stop working properly.
                        Some keys not working like Q,Z,C and some keys show deferent chr$ if i press K i will get I press D for F4 key etc...
                        i have tried all software issues like drivers test the keyboard on Windows 10 and Windows 11 and Linux with same problem.
                        I have check the keyboard connector on the mainboard every thing looks ok.
                        Then i replaced the keyboard with new one ......same problem exact same keys problem.
                        I need your advice if anyone face...
                        11-13-2023, 09:50 PM
