Samsung P2770FH blank screens.
  • BigTroll
    • Sep 2010
    • 1317
    • LAMBDA SOND
    So I just got this monitor for free, It needed a powerbrick, however, after a short time of operating if the image on the screen is mainly black the screen will shut off then come back on and shut off again progressing to long shut offs each time.
    to test this theory I let agar.io run which has a mainly white background, the monitor would stay on with out flicking, the moment I minimized the browser the monitor would shut off and stay off, if i clicked maximise on the web browser with the monitor off, it would magically come back on, the monitor just hates black images for some reason. I have moved it from computer to computer and tried different inputs and the same stuff happens. also when it is on for a long time over 30 mins it will even shut off on white screens.
    Right now I have it apart, the input board has some samyoung surface mount caps I was planning to replace, not sure what series but I ordered some panasonic FRs to replace them and hope that will fix it. any advice for this bastard of a p2770fh is much appreciated.
    My Computer: AMD Ryzen 9 3900X, Asrock X370 Killer SLI/AC, 32GB G.SKILL TRIDENT Z RGB DDR4 3200, 500GB WD Black NVME and 2TB Toshiba HD,Geforce RTX 3080 FOUNDERS Edition, In-Win 303 White, EVGA SuperNova 750 G3, Windows 10 Pro
    09-07-2024, 05:50 AM
    by momaka
    03-15-2023, 10:17 PM
  • RetroComputingGrotto
    Hanns.G Hi221 Monitor - Works For A Second & Then Blank Display
    by RetroComputingGrotto
    I've got a Hanns.G Hi221 Monitor that works for a moment and then the display goes off but the power LED indicator remains on. If you power it off and back on again it does the same thing, it comes on and then the display goes blank. From a cold start it takes 10 seconds or so before the display goes blank but if you turn it off and then back on again after it already being on it goes blank a lot quicker so I'm assuming something is getting hot which is causing the display to go off.
    I've uploaded a video of it happening on YouTube:
    I've taken the monitor...
    01-11-2024, 05:37 AM
    09-06-2024, 11:40 PM
