Samsung LS24A300H LED Monitor
  • smallprint
    • Nov 2010
    • 86
    I have a samsung LS24A300H led monitor about 3 years old only a year out of warranty and the mainboard has died and i can't seem to find one anywhere the part number i require is BN94-06637U does anyone know where i might find one as they are proving to be like rocking horse shit at the moment.
  • 1supertech
    • Apr 2012
    • 384
    Re: Samsung LS24A300H LED Monitor
    You may have a bad fuse F901 if you have an ESR meter you can check caps
      master hoarder
      • May 2008
      • 12175
      • Bulgaria
      How did you determine the main board is bad? Did you check any of the voltage rails?
      I see several inductors. Those are probably for buck regulators. See what voltages you get. Also, what are the symptoms of the monitor?
        09-07-2024, 05:50 AM
      • keepread
        Dell monitor PSU vs Dell laptop PSU
        by keepread
        Hi there!
        Someone gave me their old monitor, it's Dell S2715ht.
        The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
        Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
        10-30-2025, 04:45 PM
        09-06-2024, 11:40 PM
        09-06-2024, 08:40 PM
