HP W22 lights up then goes dark.
  • shipwise
    • May 2011
    #41
    Re: HP W22 lights up then goes dark.
    New user here!, I have four cfl in my view sonic, there is one cfl that seems to
    cause the others to flicker and then go out, if I unplug one that I believe is bad I
    have a bright screen but still goes out after 1-2 seconds with it unplugged , which suggest the the cfl is bad, but would simply unplugging the bad cfl allow the others to work with out shutting down after 1-2 seconds
    Or must the fourth bulb be pressent and working, for it to stay on?
    I did not want to buy a bulb just to see, since I already replaced cap's
    Kind Regards,
    • PlainBill
      • Feb 2009
      • 7034
      Kind Regards,
      The protection circuit will shut down the backlights unless all CCFLs are connected and working properly.
      PlainBill
      • rash.m2k
        • Apr 2010
        • 64
        Hey mate, the pics on the first page looks suspicuously like my NEOVO monitor, could you please post a pic of the whole board.
        Maybe I could buy a LCD with a cracked screen and save me some soldering! hehe
        • alexanna
          • Mar 2010
          • 1346
          #44
          You would be surprised how many CCFL assemblies are interchangeable between monitors.
          If you are working on a 22” monitor look for a true 22'' screen, Not one that's 21.5 and marketed as a 22”.
          The other critical measurement is the thickness of the screen,most of the newer monitors are using a really thin screen where as some older monitors have a thick screen.
          • Rozp
            70LE660U dark cloud or black screen with sound.
            by Rozp
            Hello Everyone,
            This is my first post so I will try to be as precise as possible without making this post too long winded. Unfortunately I don't have pictures of the original problem but I included images of the TV internals.
            I have a Sharp 70LE660U. The problem started a few months ago with the bottom row looking out of sync and was dark on the left side and then fading to transparent on the right side. Shortly after, a dark cloud appeared in the center of the screen. The dark cloud started small and shaded but the image was visible. It also affected the menu area....
            08-29-2023, 05:25 PM
          • Francesc V.
            Christmas lights - Something I am doing wrong
            by Francesc V.
            Hi:
            i am trying to repair this Christmas lights from my parents. They are incandescent lights, no led lights.
            I have tried with 12V a 24V small lights that I found in Aliexpress but is obvious that are not the right ones. They last microseconds connected. Do they blow because of Amps or Volts?
            If I measure the Amps in the string........it's only 90mA. If I measure the Volts in the "green box"......it's between 0 and 190V, but doing a little bit of maths from the number of bulbs in series.......it's only about 6V per lamp.
            Could...
            03-11-2023, 07:38 AM
          • Danstona
            LG 65UK6090PUA - picture dark
            by Danstona
            Was watching this set, and suddenly it went dark. Picture is still visible, just very dark. Tried checking all settings, adjusting brightness to 100% no change. Reset through menus, no change.
            bought used boards from ebay (power and input boards) replaced with same results, changing brightness does seem to have a slight affect.. but not to normal visibility of picture.
            I'm handy, fixed TVs before.. I can't see any issues with boards... hoping someone can point me in the right direction to properly diagnose. I don't believe the LEDs are caput, since the picture is on and equal...
            03-10-2024, 12:41 PM
          • bialag
            Lenovo ThinkPad E14 Gen 5 - Not Powering On - 3 Blinking Lights - 20 volts 0.224 amps
            by bialag
            I have a Lenovo here that does not want to power on. The motherboard appears to be clean, no sign of corrosion or obvious fried components. When plugged in, I see 3 blinking lights and then off. It would cycle the 3 blinking lights every 10 seconds or so as long as I have the adapter plugged in. Amp meter shows 20 volts, 0.224 amps, no fan spin, red light indicator near the charge port.
            Thermal camera shows a section of the motherboard that is warmer than the rest. It is near the connector labels JRTC1 (CMOS battery). Diode measurement to ground for pin 1 = OL,...
            03-25-2025, 05:56 PM
          • bohaboha
            Samsung UE70TU6905 BACKLIGHTS AND SOUND ON NO PICTURES BUT SCREEN NOT DARK
            by bohaboha
            Hi it looks like everything works don't know where to test except the 390v in the 2 capacitor in the hot side of the power supply and the weird 180v in the diodes in the cold side that should be discharged it is writin on the circuit no more you can read what is written on the circuit quite srrange color mixiing yellow and white
            anyhow i couldn't t read anything else
            the backlight is on strong and the screen does not get dark or very dark but no pictures
            the mainborad feels a bit hott on the black part i test it to 52 degree's against 34 to 40 on the rest of it
            01-02-2025, 08:04 PM
