HP LCD with bad caps
  • dood
    Deputy dood
    • Mar 2004
    • 2462
    Unfortunately, I didn't get the model off this monitor before I returned it. Just a basic older 15" LCD. Would not turn on or even flash the power light when it came to me.
    Recapped with panny's
    Replaced all but the main cap (it was already a nichi) just for good measure.
    I should probably organize my desk.
    Lookin' good, now.
    Ludicrous gibs!
  • ant3202
    • Jun 2006
    • 275
    • Singapore
    Re: HP LCD with bad caps
    good work!
    btw panny caps u r using is FM series?
    • dood
      Deputy dood
      • Mar 2004
      • 2462
      Yep, panny FMs
      Ludicrous gibs!
      • ant3202
        • Jun 2006
        • 275
        • Singapore
        i see thanks
        • Krankshaft
          • Jan 2007
          • 2328
          I use FCs on my inverter recaps they work well too.
          This is why I say that Crapxon caps are dodgy at best they are like Teapos sometimes they work great and sometimes they fail.
          • dood
            Deputy dood
            • Mar 2004
            • 2462
            Capxon seem okay as long as they're adequately cooled. In this LCD screen there would obviously be a lot of heat buildup.
            Ludicrous gibs!
              by momaka
              03-12-2025, 03:42 PM
            • eryjus
              by eryjus
              05-10-2023, 11:21 AM
            • Paxman_Swede
              by Paxman_Swede
              Hello!
              01-14-2025, 09:51 AM
            • captain150
              by captain150
              03-16-2025, 07:34 PM
            • Foetuss
              Gigabyte GA-6OXT :: caps question
              by Foetuss
              Good evening
              I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
              Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
              But I was also suprised about the bigger boys, which are 330µF 25V.
              Could it be they used 25V caps because they were cheaper / available at that time?...
              02-11-2025, 12:22 PM
