Problems with Samsung 740N monitors
  • qbicdesign
    • Dec 2014
    • Estonia
    #441
    Re: Problems with Samsung 740N monitors
    To everyone posting here, this thread is gold dust!
    I have one 740n with the 3 blown caps (which i already replaced) and the blown 3A picofuse, which I'm waiting on.
    I also have 3 of the 740n monitors with the circuit board from pic 1 referenced here on the very first page in this thread:
    https://www.badcaps.net/forum/showpo...18&postcount=4
    I'd like to know if (beyond replacing the bulging caps), is there any fuse replacement on this board?
    • Behemot
      • 4845
      • CZ
      #442
      Can't see anything, the picture is terrible. It may very well be under the second board, just have a look yourself, fuse is F.
      • qbicdesign
        • Dec 2014
        • Estonia
        #443
        seems I have answered my own question.
        I replaced the bulging 1000uf 10v with a 16v which I had salvaged from an old mobo.
        There's a single 470uf 25v which lays horizontally next to the mosfet board. I didn't have a same replacement, but figuring that the board printing states 13v, i put a 470uf 16v there (also salvaged from an old mobo).
        The 3 monitors are now working!
        There are some other still bulging CapXom capacitors rated at 470uf 25v, which I'll replace as soon as I can get to the store. But as proof of concept, I know that my monitors are OK.
        The cool thing is that I have about 40 740n monitors, which seem to be dying on a fairly regular basis with all the same symptoms (flashing blue light, no image on screen), and now I know how to fix them all
        All of those monitors shared the same symptoms, same swollen caps, in all the same locations. It should be enough to switch out (per monitor) 3x 470uf 25v, 1x 1000uf 10v.
        Again, thanks to all posters in this forum for your contributions!
        • Behemot
          • 4845
          • CZ
          #444
          I can supply you with quality caps, maximum capacity in each dimension and too extremely low ESR. PM me for more information…
          • skydec
            • Mar 2014
            • Croatia
            #445
            Just repaired 2 samsung 740N LCDs.
            On the first one I just replaced the 3 capacitors on 13V rail and that was it, worked after that.
            Second one was a bit tough. It was completely dead, LED also dead. Fuse, thermistor and varistors were OK. ZD102 was found dead, replaced it but it didn't help. After I powered the LCD still nothing, replaced zener didn't burn. Comparing ohm readings form first LCDs psu I saw lower ohm readings across several components in primary side of the second LCDs psu (Zener diodes were not reading as (600,infinity) but (200,200). So I decided to swap the DM0565R and now the second psu is also working. The faulty DM0565R was not in short circuit but still is not working properly.
            • tvl_svl06
              • May 2015
              • 23
              • india
              #446
              samsung 740n monitor display in 2 sec.. go to screen block mode
              display time inverter input voltage 14.0v
              inverter power input 18.5v this voltage is normal?
              change 470mf25v cap.3no,1000mf25cap no1
              send more information
              • Behemot
                • 4845
                • CZ
                #447
                Seems like open-circuit voltage is high, should be OK under load. Replace all caps, usually all of them go bad even though it may not be visible. Check inverter transistors and transformer(s), everything is coverd many times in this thread.
                • tvl_svl06
                  • May 2015
                  • 23
                  • india
                  #448
                  change all cap,cheeking inverter transformer normal
                  • selldoor
                    Slow Learner
                    • Dec 2010
                    • 7870
                    #449
                    No use saying transformer is normal - what are the secondary
                    winding resistances.
                    • tdr
                      • 30
                      • Lithuania
                      #450
                      I changed the bad caps and now I got the screen running but with some vertical colored stripes on the right side of the screen. Is that because of loose connection somewhere and can it be fixed? Thank you.
                      • Behemot
                        • 4845
                        • CZ
                        #451
                        Try reseating the LVDS but it may bad panel too.
                        • tvl_svl06
                          • May 2015
                          • 23
                          • india
                          #452
                          af4502c mosfet equlant
                          • Behemot
                            • 4845
                            • CZ
                            #453
                            You can buy 10 of them from eBay for 2 bucks free shipping http://www.ebay.com/itm/10PCS-MOSFET...item3f2a9b8e7d
                            • tvl_svl06
                              • May 2015
                              • 23
                              • india
                              #454
                              Samsung 740n white screen
                              • Behemot
                                • 4845
                                • CZ
                                #455
                                Reseat LVDS cable, than bad display.
                                • tvl_svl06
                                  • May 2015
                                  • 23
                                  • india
                                  #456
                                  reset cable no display
                                  • tvl_svl06
                                    • May 2015
                                    • 23
                                    • india
                                    #457
                                    Samsung 740n some line vertically,no display
                                    • tvl_svl06
                                      • May 2015
                                      • 23
                                      • india
                                      #458
                                      monitor screen shot
                                      • ghost52+
                                        • Sep 2015
                                        • greece
                                        #459
                                        Hi.I am new member and i have a problem with this monitor.It doesn t turn on and it hasn t the stby light on.I take the ps board to look at it but i didn t see something blown up or the capacitos in a bad condition.Any idea what to do?
                                        • tvl_svl06
                                          • May 2015
                                          • 23
                                          • india
                                          #460
                                          how to solve this problem
                                            09-07-2024, 05:50 AM
                                          • vincentedel
                                            Samsung SyncMaster 740n Phase Control Issue
                                            by vincentedel
                                            I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some timeβ€”like after playing a gameβ€”the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
                                            I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
                                            04-22-2025, 12:33 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
