VGA scan conversion alternatives
+ More Options
Posts
  • Logistics
    • Apr 2007
    • 721
    Re: VGA scan conversion alternatives
    Originally posted by pentium
    As in a preferred resolution? It's hard to tell. I assume it was something like 640 x 480 as back then that was still commonly used.
    Why are you asking?
    I was curious as to their resolution capabilities.
    "3D stereoscopic Smart Visor - 789(RGB)x230 resolution x 2
    263x230 True Pixels"
    Is this a limitation of it's original video input or the LCD's themselves?
    Presonus Audiobox USB, Schiit Magni 3, Sony MDR-V700
    • davmax
      • Dec 2005
      • 899
      #42
      So does fig. 1 look okay?
      Yes.
      However I have concerns about the C synch signal. Searching the net reveals the c synch is negative going, so is the c synch out of the synch converter. Passing this synch signal through the DG541 will invert the signal to positive going implying that the VFX1 requires a positive synch pulse that is non standard. This inversion is stated on the original circuit you posted so I guess it is correct.
      Gigabyte EP45-DS3L Ultra Reliable (Power saver)
      Intel E8400 (3000Mhz) Bios temps. 4096Mb 800Mhz DDR2 Corsair XMS2 4-4-4-12
      160Gb WD SATAII Server grade
      Nvidia 8500GT 256Mb
      160Gb WD eSATAII Server grade for backup.
      Samsung 18x DVD writer
      Pioneer 16x DVD writer + 6x Dual layer
      33 way card reader
      Windows XP Pro SP3
      Thermaltake Matrix case with 430W Silent Power
      17" Benq FP737s LCD monitor
      HP Officejet Pro K5300 with refillable tanks
      • pentium
        • Mar 2006
        • 2778
        Are you talking about the VFX1 in particular?
        Find Nedry!
        Check the Vending machines!!
        <----Computer says I need more beer.
        • davmax
          • Dec 2005
          • 899
          #44
          Pentium. Have you seen this thread?
          http://www.stereo3d.com/discus/messa...tml?1159470122
          It would seem the task is not simple. See how you go.
          Nvidia 8500GT 256Mb
          33 way card reader
          Windows XP Pro SP3
          • pentium
            • Mar 2006
            • 2778
            Seen that and almost every link is dead.
            I refuse to use whatever info they provided as we already have nearly an identical setup (but differently designed).
            We just need to finish these schematics and we will be ready to make a prototype.
            Find Nedry!
            • pentium
              • Mar 2006
              • 2778
              Changes have now been made so that all voltages required for the project to work (+5V, -5V and +12V) now come in from an external source.
              I'll take some photographs and post the latest revision of the schematic shortly.
              EDIT: here they are.
              Find Nedry!
              • davmax
                • Dec 2005
                • 899
                #47
                Checked wiring looks good. Worth a try now.
                Nvidia 8500GT 256Mb
                33 way card reader
                Windows XP Pro SP3
                • pentium
                  • Mar 2006
                  • 2778
                  Okay then, I will make up a parts list and the next time I go to the hobby store I will order the parts.
                  Find Nedry!
                  • pentium
                    • Mar 2006
                    • 2778
                    The second headset, the controller and all the other stuff was picked up last night.
                    The schematics have been cleaned up a bit so you can see the lines better.
                    The next step is the building of the box and the system.
                    However my christmas vacation time has run out and that will have to wait for another day....and as soon as I have the money to buy the needed parts.
                    I'll report back once I have tested the box.
                    Find Nedry!
                    • davmax
                      • Dec 2005
                      • 899
                      #50
                      Because we have patched circuits together there is every possibility that there will be timing problems. I have read that these headsets require a TV video signal that has a specific line and frame rate that is different to VGA.
                      A guaranteed solution can only be had if the headset requirements are well understood. I suspect that the reason the bulky expensive modules were specified originally is that they do deliver synch and RGB at the required TV spec.
                      I am about to scan through the VFX1 info on the group site you recommended.
                      Nvidia 8500GT 256Mb
                      33 way card reader
                      Windows XP Pro SP3
                      • davmax
                        • Dec 2005
                        • 899
                        #51
                        Take a look at this link that defines the problems. It seems the synch circuit we chose to use will not work without special drivers.
                        http://www.epanorama.net/circuits/vga2tv/index.html
                        What I have noted is that is is said that PC video cards with TV out are good at providing the correct conditions. The snag is. How to split the vision to stereo? This is getting more difficult than I am willing to go at this time. You need better help. It seems many have struggled with this issue. I cannot see a solution yet. Sorry about that. Partiularly that you have bought stuff.
                        Nvidia 8500GT 256Mb
                        33 way card reader
                        Windows XP Pro SP3
                        • pentium
                          • Mar 2006
                          • 2778
                          Well we cab just cross our fingers and hope.
                          Find Nedry!
