Dell e173fpf lcd monitor ?
  • buckiejr
    • Sep 2007
    Hello i have a Dell e173fpf that will shut off once out of 5 times when i push the power button the green light comes on and the display comes on put then when the monitor warms up it will not shut off.
  • Krankshaft
    • Jan 2007
    • 2328
    Re: Dell e173fpf lcd monitor ?
    Check the secondary capacitors on the inverter you probably will find that they are bulged.
    If so replace them with a reputable brand like Panasonic FC series from Digikey and you will be all set.
    I recently recapped that exact same monitor removing the rear cover is a major PITA. There are no screws just plastic clips. To remove the back cover lossen the 4 screws securing the monitor stand to the back of the monitor.
    Then get a flash light and look through the ventilation slats on the sides you will notice 2 black plastic clips on each side.
    Now using a knife I used the bottle opener on my swiss army knife. I inserted the hook into the slat and pressed outward the casing will make a snap sound. Do the same for the other 3 clips on both sides.
    Now using a knife gently pry upward along the casing and the clips will begin to release until the cover comes off.
    Once you're inside loosen the screws securing the metal heat shield covering the inverter.
    • Borse2008
      by Borse2008
      • There’s
      07-15-2025, 04:55 AM
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • DanPoka
      by DanPoka
      02-15-2025, 05:05 AM
      by momaka
      03-15-2023, 10:17 PM
    • Jesus Coder
      Issues Reviving Old Dell 2408WFPb Monitor
      by Jesus Coder
      I have been having some difficulties reviving an old Dell 2408WFPb PC monitor that I received for free. When I first acquired it, the backlights of the display were on but alas no image was showing. After extensive research on the topic, I went ahead and purchased a new t-con board for the monitor. After installing the board, I was then presented with a new screen that was half black and half green (more so black). I have been unable to figure out what to do next as I have limited knowledge of display electronics. Might anyone on this forum have an idea of what may...
      06-25-2023, 02:33 PM
