Fujitsu EM1820W no power
  • bappies7
    • Aug 2011
    • 41
    I have this Fujitsu EM1820W, just one fine day it just refused to power on.
    No standby light, no light nothing at all.
    Anybody have the service manual or schematics for this model?
    Thanks.
  • PantherDave
    by PantherDave
    Hi all!
    05-29-2024, 02:01 PM
  • ipatch
    troubleshooting microsoft surface pro 4 no power no led charge light
    by ipatch
    hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
    10-05-2023, 11:59 AM
  • russpall
    LG 39ln540v - red light flashes twice, no power to LED driver?
    by russpall
    Hi there,
    I've got a 39" LG 39LN540V that's just spontaneously stopped working! The symptoms are - when I plug it in, the red light will flash on twice, then go out, there's no visible picture, and I couldn't see anything using a torch on the panel either. If I press the power button (either remote or on TV), the red light comes on continuously. If I press power again, the red light flashes twice.
    The TV is using a power board EAX64905301. I've attached a diagram of the power output, I've tested the voltages with a multimeter and I'm getting the following:
    08-27-2024, 01:07 PM
    03-31-2024, 02:12 PM
    Laptop computer that went completely dead no boot no power light no hard drive light
    See pictures for type of laptop computer
    I checked switching power supply brick 19.2 volts multi meter only
    No booting without switching power supply connected
    Checked switching power supply with an (28 volt ) incandescent light bulb it lights then hooked up the switching power supply again now the laptop and boots like normal
    What the heck is going on here...
    04-04-2025, 04:58 AM
