Dell 2408WFPb backlight colour
  • HAHOMETP
    • Nov 2012
    • 155
    I am puzzled, folks. I have two identical Dell 2408WFPb monitors. In both I have replaced some low reading and/or bulging caps. One of them also had 2 out of 7 backlight CCFLs broken. I bought a cracked Samsung LTM240CS05 panel on ebay which may or may not in its previous life have been installed in a Dell and swapped the whole backlight into mine. Here is a picture of the two monitors side by side. Both have been reset to default picture settings first on the monitors themselves, then in the video card's (nVidia Quadro FX 1700 with 2 DVI inputs) control panel. As you can see the left one (with the original Dell backlight panel) has a decidedly cooler hue than the right one (with the donor backlight panel). If I swap the DVI cables at the video card, their respective colours do not trade places, so it is in the monitors themselves, not in the card settings.
    Question. Assuming that the second backlight did not come from a Dell monitor, is it possible that Samsung would use CCFLs with different colour temperatures in the panels with exactly the same p/n?
  • Compgeke
    • Feb 2014
    • 524
    Re: Dell 2408WFPb backlight colour
    I've noticed similar stuff with a couple different Dell 1704 monitors but I've never heard of different backlight temps for the same panel model.
    I would try playing around with the colour settings on-screen to see if you can make it look any better. Raising the blue and\or lowering the yellow looks like it might help, probably not perfect.
    Checking the voltages going to the backlight would also help to see if the one on the right is getting a lower voltage than it's supposed to have.
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • juergenb
      Dell Precision 3660 - BIOS Image, Hidden Settings, Thermal Settings ?
      by juergenb
      I got my self a new Dell Workstation (Dell Precision 3660, i5-13500).
      Unfortunately, Dell has fixed the front fan“s settings in the BIOS.
      Both the speed and the presence of the fan are fixed.
      There seems to be no hidden setting.
      The thermal tables for the speeds were changed in one of the last BIOS updates.
      Do you see a possibility to change these tables from the BIOS update file?
      Precision_3660_2.1.0 -> Release Notes
      Updated the thermal table to reduce fan noise.
      Updated Intel Management...
      08-12-2023, 03:50 AM
    • doctormasry
      dell 3521 la-9104p no backlight
      by doctormasry
      hellolaptop dell 3521 la-9104p no light on screen
      i can see data ok but no backlight
      on jlvds
      NV_PWR_SRC 18 v is ok
      3vs is ok 3.3
      lcdvdd is ok 3.3
      i replacd led screen
      and change flata ( caple between board and led )
      any idea...
      09-11-2025, 12:14 AM
    • triplefour
      by triplefour
      09-13-2023, 10:43 PM
    • miosz
      Dell Inspiron 15 3558 - no backlight
      by miosz
      I'm trying to fix friend's Dell, it had liquid damage in the past, but as far as I know it was fixed in professional service. It was working fine for quite some time, except for dead battery, but recently there was blackout in the building and after power was restored, laptop was broken. When I got it, it was posting, but OS didn't boot, also backlight was gone. After some tinkering I switched off secureboot and it started booting normally, but backlight issue persisted. I opened it up and started looking for issues. Checked both fuses on display and all fuses on motherboard which I...
      03-12-2024, 07:21 AM
