Samsung syncmaster 2443w easy fix ?
  • bakke33
    • Oct 2014
    • Sweden
    Got hold of a Samsung Ayncmaster 2443bw last week.
    Thinking it would be an easy fix with bad caps.
    The fault was that the screen died, no response on the touch buttons. No blue led.
    Before that there was problems with the OSD menu. It popped up on the screen randomly sometimes and it could not be controlled with the touchbuttons until power off/on.
    Anyway I found this on youtube: https://www.youtube.com/watch?v=djn3tFunhCQ
    So I changed the 4 caps on the logic board.
    It did not work, so I opened it again and began measuring the voltages on the 5v,3,3v and 15v. ( Se picture below for the points)
    When I did that it suddenly began to work.
    So I reassembled it and had it going for 6h and then it died again.
    Going back to measuring the voltages I noticed that the live part of the power board is ok.. but when going to the logic part I cant see any good voltages at all.. When I measure the 15v line I can see the voltage meter dropping from 11v to 0v... Like a cap is draining ?
    I also changed all caps on the power board but there was no go there to.
    Any ides on how to proceed ?
    The power board is similar to this picture
    I'm thinking that the coil ( is that the correct name for the copper "transformer" to the upper left in the picture is broken ?
    I've also measured the mosfets on the power board. They seem ok but I've only tried the basic test with the multimeter.
    So how can I check if the coil is broken ?... I doesn't out put any voltage at all when connected.
    Any other ideas ?
    Regards P
  • kasfamily
    • Aug 2014
    • 774
    • Russia
    Re: Samsung syncmaster 2443w easy fix ?
    Check IC601 and IC602 SM -
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
    • ohren
      Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
      by ohren
      I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
      I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
      The models launched in 2018 and 2019 respectively....
      09-08-2023, 05:24 PM
    • C152Heavy
      Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
      by C152Heavy
      Summary for TL-DR readers:
      • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
      • Have obtained Samsung schematic & service documents - Can upload if helpful.
      • Have read ALL applicable threads
      • C1818 and CP820 replaced as low hanging fruit
      • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
      • VCC pin (18) of PFC...
      01-11-2023, 02:53 PM
      09-07-2024, 05:50 AM
