Sync-on-green
  • pentium
    • Mar 2006
    • 2778
    Sync-on-green
    Every SGI I own uses the bloody standard and it's really annoying.
    The only compatible SOG monitors I own are my 21" IBM P201 monitors and my one bad SGI monitor for my Personal Iris, all of which are used in a constant basis.
    I have so many regular VGA monitors floating around it's not funny however they don't accept the SOG standard and do nothing when connected to an SGI.
    Since regular VGA uses a separate Sync line, how hard would it be to separate the sync signal from the green pin? I need four or five of these too.
    Find Nedry!
    Check the Vending machines!!
    <----Computer says I need more beer.
  • gonzo0815
    • Feb 2006
    • 1600
    Re: Sync-on-green
    I think it should be possible with a few simple signal spliter.
    E.g. a smith trigger or may be a simple, fast diode to separate the negative sync signal, then may be a lo pass filter to seperate the H and the V sync (V sync ist a mutch higher frequency).
    Then add some TTL level shifter and may be an polarity inverter and your done.
    It is not that i could make this circuit in a few minutes, but if someone is trained with basic TTL level conversion, it should be not that hard.
    • Maxxarcade
      • Jul 2006
      • 973
      Re: Sync-on-green
      I'm pretty sure they make adapters to connect specific models of Sun systems to VGA monitors.
      In fact there is a seller on Ebay, "deepspacecables" I think, that sells different adapters. I would assume that some have sync converters built in, and some do not, since they claim there are different types of adapters for certain systems.
      One that seems to support SOG is item #150152186197.
      • pentium
        • Mar 2006
        • 2778
        Re: Sync-on-green
        If you are implying about the 13W3 connector then I am prepared.
        deepspacecables looks expensive.
        Find Nedry!
        • grimacelord
          PS4 CUH-2115B Slim All Controllers Do Not Sync By Bluetooth or USB
          by grimacelord
          Hello. I have a PS4 Slim model number CUH-2115B that is having a problem with syncing any controller by USB and Bluetooth. Every controller I have tried will not sync, and I know that the controllers will sync fine to another PS4, so it's not a controller problem. I have tried 5 different USB cables and 3 different controllers and none of them sync to this PS4, but will on others.
          The USB ports on the PS4 is delivering 5V power and does charge the controllers (I checked with an USB ammeter).
          The controllers also do not work in Safe Mode. I understand that if they...
          08-08-2022, 09:04 AM
        • BigOof
          Pioneer RM-07 Active monitors cutting out from time to time
          by BigOof
          I have a pair of Pioneer RM-07 monitors that I bought a while ago. When I was testing them I noticed that one speaker would cut out and I thought it was just a bad cable connection. At the price they were being sold for I was willing to take a risk on them. However, 6 months later and the one monitor still has the same issue. Most of the time it works, but there are times that the power LED is on but I get absolutely no sound. I can hear the relay clicking on/off sometimes and then it will/won't work depending on what it feels like. I've tried XLR and RCA inputs with the same issue. There's no...
          12-18-2024, 04:35 AM
          Asus G751J (G-Sync) Gaming Laptop Schematic
          Asus G751J G751JM (G-Sync) Gaming Laptop Schematic...
          11-01-2024, 06:17 AM
        • baldharry
          Sync stripper, unknown IC
          by baldharry
          Hello all,
          Can anyone help me identify the chip marked with a red circle in the attached picture. I'm pretty sure it is Analog Devices component but which one. The component is part of an sync-on-green signal separator.
          Thanks in advance....
          03-07-2024, 10:33 AM
        • CoinCoin88
          Garage door RX unit (Cardin S38C) does not short relay to send opening signal
          by CoinCoin88
          I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
          Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
          09-15-2025, 03:36 AM
