Sync stripper, unknown IC
  • baldharry
    • Jan 2023
    • 17
    • .fi
    Hello all,
    Can anyone help me identify the chip marked with a red circle in the attached picture. I'm pretty sure it is Analog Devices component but which one. The component is part of an sync-on-green signal separator.
    Thanks in advance.PCB
  • baldharry
    • Jan 2023
    • 17
    • .fi
    Case solved, the IC is identified as AD8061/AD8062/AD8063.
    • Stachujones
      Dell XPS 13 9370 unknown USB devices in device manager
      by Stachujones
      Hello, i bought a faulty Dell xps 13 9370 after installing windows in device manager i Can see 2 unknown devices, one is thingerprint reader because it dissapears after i unplug it and second one is i believe bluetooth because it also doesnt work and in bios there is no bt also.
      Device manager says "unknown device, failed to request device descriptor"
      Can somebody point me in right direction what to check?
      I updated bios to the newest version and thunderbolt controller firmware still no luck
      04-05-2025, 07:35 AM
    • apostsamking
      dell latitue e5450 AC Adaptor unknown
      by apostsamking
      Hello everyone hope all is well. Pls I bought this second hand dell latitue e5450, I realize that the battery cannot be charged because it says ac adopter unknown at bios. I tried several chargers but still I get the same messageAC Adaptor unknown. So I open the laptop up checked the motherboard and i realised that the diod PD5 is fried so I changed, but I still get the same message, changed even the charging ic still the same message AC Adaptor unknown. Can any one help me?
      02-19-2023, 03:45 AM
    • TheUser
      Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
      by TheUser
      Hello to everyone ,
      This is my first post here, and i would like to share with you a small story in case you can help me.
      Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
      All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
      I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
      02-10-2024, 02:07 PM
    • mshone
      Lenovo thinkpad P1 G2 UUID and Serial number/mashine type unknown
      by mshone
      Sorry if topic if misplaced. Have lenovo thinkpad P1 gen2 with Xeon E-2276M CPU and NVIDIA® Quadro® T1000. It is a new board replaced. Old board was P1 G1 model with i7 and it is defective. I ordered a new one with xeon, but is gen 2. Laptop case is suitable for this motherboard, with some little difference (GPU fan and subcard).Ok, ordered and replaced and GPU fan and subcard and now laptop is working fine, but serial number and UUID is unknown. Ok, i readed several topics here and found Thinkpad maintenance disk, but.....which values to type? How to find data base with those values? serial...
      08-29-2025, 06:41 AM
    • grimacelord
      PS4 CUH-2115B Slim All Controllers Do Not Sync By Bluetooth or USB
      by grimacelord
      Hello. I have a PS4 Slim model number CUH-2115B that is having a problem with syncing any controller by USB and Bluetooth. Every controller I have tried will not sync, and I know that the controllers will sync fine to another PS4, so it's not a controller problem. I have tried 5 different USB cables and 3 different controllers and none of them sync to this PS4, but will on others.
      The USB ports on the PS4 is delivering 5V power and does charge the controllers (I checked with an USB ammeter).
      The controllers also do not work in Safe Mode. I understand that if they...
      08-08-2022, 09:04 AM
