Samsung Monitor S19F350 19
  • bennn
    • Mar 2023
    • 15
    Samsung Monitor S19F350 19" Main Board LS19F350 SF350 (P/N: 2017219005D121)
    Hi! The backlight doesn't work, but the board itself works. I checked every diode on it and they all light up. Shim is definitely working as I changed it for a new one.
    I found the datasheet for a similar chip OB3351.
    VCC (1 leg)
    14v comes
    VDD (leg 14)
    It has 3.5v.
    Smd capacitance checked C913 it has a thousand nanofarads.
    vLos-1.2% looks like it is working.
  • CapLeaker
    Leaking Member
    • 8352
    How much voltage are you getting on the LED string? LED connected nd disconnected.
    • lotas
      • Jan 2016
      • 4905
      • Russia
      What is the voltage on the control pin (enable)?
      • bennn
        • Mar 2023
        • 15
        Hello! 3.5V.
        I also want to add that I put a new ice driver from China as I know that they often fail.
        That is, the OB3351cp is new and definitely working.
        By the way, I found before that the 2nd leg was planted on the ground and it was the r919.
        I took it off and a short passed and the chip started up.
        I also want to add that before that I checked the led bar
        by applying voltage to each LED and all of them are definitely working.
        • bennn
          • Mar 2023
          • 15
          I'm sorry, English is not my first language. Can you paraphrase?
          • CapLeaker
            Leaking Member
            • 8352
            Measure the backlight voltage on the LED string connector twice, Once with the connector plugged in and one unplugged.
            I wanna see what it does when you turn the TV on.
            • lotas
              • Jan 2016
              • 4905
              • Russia
              If pin 2 is grounded, then the mosfet is most likely broken, have you checked it?
              • bennn
                • Mar 2023
                • 15
                Thank you very much for your help.
                1.There is no difference if the voltage is static.
                • bennn
                  • Mar 2023
                  • 15
                  1.If I understand correctly, it is him.
                  I checked it with a tester, and I can say for sure that it's out of order.
                  2.Both of its contacts are connected to the ground, which is definitely not the case.
                  Plus, the low resistance from 2 contacts has not gone away.
                  • CapLeaker
                    Leaking Member
                    • 8352
                    a mosfet has 3 contacts. The tab on the rear is connected to the middle pin and then there are the two outer pins. Gate, drain and source. So your second pic above is wrong, because the middle pin and the tab aren't in the calculation there.
                    • bennn
                      • Mar 2023
                      • 15
                      Okay, but in the 3rd picture it is pressed with all the contacts and also shows incorrectly.
                      • CapLeaker
                        Leaking Member
                        • 8352
                        I don’t really trust these cheap little component testers and just test MOSFETs with my DMM, as I want to see that mosfet turn on and off again. What part number is written on the mosfet?
                        • bennn
                          • Mar 2023
                          • 15
                          pb210bd
                          • lotas
                            • Jan 2016
                            • 4905
                            • Russia
                            What resistance does the multimeter show between the three pins on this mosfet?
                            • CapLeaker
                              Leaking Member
                              • 8352
                              Funny, it did see the body diode in the mosfet, but not the gate. Solder a little leg to the middle pin and use the socket again on the component tester… just curious…
                              but to really check that mosfet, test it with your DMM.
                              • bennn
                                • Mar 2023
                                • 15
                                Gate–Source: >0.L
                                Gate–Drain: >0.L
                                Drain–Source: 1.44 kΩ
                                • bennn
                                  • Mar 2023
                                  • 15
                                  I thought it was interesting too, so I soldered the leg on. That apparently the problem is not in him for sure. Something is putting the other leg on the ground.
                                  • lotas
                                    • Jan 2016
                                    • 4905
                                    • Russia
                                    Originally posted by bennn
                                    Gate–Source: >0.L
                                    Gate–Drain: >0.L
                                    It's broken, burned out, throw it in the trash, put in a new one.
                                    P.S. Drain–Source: 1.44 kΩ, short-circuit all three pins together (when measuring with a multimeter, there may be a charge remaining, between Drain–Source it should show as a diode if you swap the probes between each other.
                                    • bennn
                                      • Mar 2023
                                      • 15
                                      Hello everyone!\
                                      I changed the mosfet transistor
                                      But it didn't help.
                                      But then I noticed this resistor.I soldered it and the backlight came on!!!
                                      • CapLeaker
                                        Leaking Member
                                        • 8352
                                        Which resistor?
                                          09-07-2024, 05:50 AM
                                          by momaka
                                          03-15-2023, 10:17 PM
                                        • keepread
                                          Dell monitor PSU vs Dell laptop PSU
                                          by keepread
                                          Hi there!
                                          Someone gave me their old monitor, it's Dell S2715ht.
                                          The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
                                          Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
                                          10-30-2025, 04:45 PM
                                          09-06-2024, 11:40 PM
