Dell 34 inch U3419W Monitor with thin stripes on partial screen
  • ChristianBr01
    • Apr 2025
    • 29
    I have a Dell U3419W Monitor that has some thin stripes on a part of the screen since Tuesday.
    This lines cover about a third of the screen and appear for 2 seconds before disappear for another 2 seconds.
    This repeats the whole time. I have not opened the case yet cause I had no time, but will try to fix it on this weekend. For me, it looks like a problem on the TCon... Am I right?
    Does someone have seen this before?
  • CapLeaker
    Leaking Member
    • 8134
    Weird for the stripes to appear and disappear every 2 seconds.
    • ChristianBr01
      • Apr 2025
      • 29
      It is weird.
      What I already tried is go through Dells suggestions on their website to solve the problem but no changes.
      I've changed the ports from DP to HDMI and replaced the cables but no changes.
      Tried to reset the Monitor through OSD, change the frequency in Linux and Windows a couple of times with the same result.
      Disconnected the Desktop and used my Laptop as Video Source... everything stayed this same. But if you look at the picture,
      you'll see that the lines appear as soon as the the panel has to display a picture on screen, even if it's a OSD without a connected video source thru HDMI or DP.
      As soon as the screen has a picture to show, the lines appear and disappear in a 2 second cycle.
      • CapLeaker
        Leaking Member
        • 8134
        Yeah, sometimes suggestions are for kinda similar problem, but not it. While a cable can do artifacts like that on a screen, it for sure not every 2 seconds in and out like clock work. Whatever it is, it’s inside the monitor.
        • ChristianBr01
          • Apr 2025
          • 29
          It's definitely inside the monitor. I opened it up and inside it is completely a LG. It was a pain to remove the small ribbon cables from the metal case cause they have been glued to it.
          Everything looks quite good but I was expecting the fault an the T-Con and I truly believe that I'm right with my thoughts.The Voltages from the PSU to the T-Con are all stable but the Voltages on the T-Con are not.
          I will write them all down and post them here cause I need here some help from someone with some experience.
          I've expected some fluctuations and that something is pulling a specific voltage down, but it's the opposite.
          As soon as the lines appear, the voltages are going up. Not too much but for example on VCC10 from 1.02V to 1.18V and on VCC33 from 3.304V up to 3.494V.
          Voltages go back to normal when the lines disappear.
          I will write them all down and post them. For me, as a beginner, it's a strange behavior or am I wrong?​
          • CapLeaker
            Leaking Member
            • 8134
            I was wondering about the voltages on the Tcon if there is any indication that the lines and voltages have something in common. Try putting a little pressure on these flimsy thin tab bonds.
            • ChristianBr01
              • Apr 2025
              • 29
              I can't believe. It was a small 0603 capacitor on the pcb where the cof strips are connected to. I couldn't find something faulty on the TCon but had fluctuations on every single voltage line.
              PSU was 100% ok and Mainboard too. Had only problems on the TCon board...
              I was just guessing and checked all the capacitors there for short circuits. I found a shorted capacitor on the left side.
              I removed it with hot air and replaced it with another one from a TV board. Everything's working fine again.
              What a strange behavior for a shorted capacitor. Have not expected this... honestly, I was 100% convinced that it's something else but not a shorted cap.
              • CapLeaker
                Leaking Member
                • 8134
                Nice repair!
                • HTR-Informatique
                  by HTR-Informatique
                  02-09-2025, 06:51 AM
                • Borse2008
                  Seeking Advice: Repairing Dell U3425WE Monitor with Faulty USB-C/Thunderbolt Ports
                  by Borse2008
                  Looking for some advice or opinions on what to do with a monitor issue I’ve run into. Apologies in advance is this crossovers a few forum categories.
                  I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display — it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:
                  • The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
                  • There’s
                  07-15-2025, 04:55 AM
                • Swedishpower
                  Dell G3 15 3500 black screen
                  by Swedishpower
                  Hello
                  I have search everywhere for a solution for my problem, but cant find it anywhere.
                  When I was away to trow some garbage i always look in the electronic bin.
                  and this time i find a laptop.
                  Dell G3 15 3500, when I get home i look at the battery, add one harddrive, plug in the powercord.
                  the lamp for charmig is white.
                  Tryed to start it, the screen blink for a second, the keyboard lightsup, the fans and HD starts.
                  but no Dell logo.
                  I tryed with a hdmi cable to another screen, still black.
                  I started to search solution and tryed...
                  07-06-2025, 06:18 AM
                • turmix
                  AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
                  by turmix
                  Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
                  The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
                  At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
                  During another reassembly, I made a mistake, and...
                  01-29-2024, 03:48 AM
                • jake-b
                  dell e6540 boots to black screen (no dell logo)
                  by jake-b
                  good morning all,
                  i purchased a used dell e6540 laptop used 10 months ago from a vendor on ebay. intel i-7 processor, 16 gb ddr3 memory, 256 gb ssd., mobo la-9413p (rev 1.0 dated 2014-08-04). i've inflicted no damage on it since purchase but its past is unknown. starting 2 weeks ago it began to fail to boot (initially 9 of 10 boot attempts failed, now 10 of 10 fail). there was no new hardware or software added (i was using as a kodi video server). the post process doesn't complete and booting no longer displays the dell logo screen - screen remains black with no backlight. some other...
                  01-08-2024, 10:29 AM
