Neotec NT-2700
  • Ace3581
    • Apr 2025
    Neotec NT-2700
    I have a Neotec NT-2700 full family. It has no picture and a few seconds after you turn it on it blows C117. Does anyone have any idea what I should look for
  • zklgfs
    Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
    by zklgfs
    I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
    08-11-2025, 02:14 PM
  • twonk9098
    Lenovo Legion 5 high fan spin turns off after 34 seconds
    by twonk9098
    I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
    I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
    I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
    I have tried a few new bios but exactly...
    07-14-2024, 11:19 AM
  • Rolin
    Lenovo Legion 5 15IMH05H No Display
    by Rolin
    I have a Lenovo Legion 5 15IMH05H 81y6003yUS that someone asked me to help them with a failing SSD. I installed a new SSD, fresh Win11 installation, updates, etc. Very standard stuff and everything was completed. He said he'll pick it up in a few days so I shut it down and set it aside.
    A few days later came and now it won't POST an image, keyboard lights up, fans spin then shuts itself off after about 40 seconds. I've already tried the typical draining capacitance and removed CMOS battery,etc. No display on an external HDMI monitor as well.. No idea what happened. Suspected a BIOS...
    06-21-2025, 11:32 PM
  • liquidzorch
    Lenovo 15iml05 Power led lights for 12 seconds then off 12 seconds
    by liquidzorch
    Hello. I bought a faulty Lenovo ideapad 3, but it turns out the 3Valw buck converter burnt a hole through the board. I was able to clean it up, and remove all the shorts. I now can power the 3.3v rails from a bench power suppy while connecting the laptop to its psu, and I get the additional 5valw, 1.8v, and 1.05v, form what I can tell in the schematics, those are the only 4 voltages I should see before turning on, and they are present. When I hit the power button, the power indicator on the left side turns on (not the one on the power button), stays on for about 12 seconds, then turns off for...
    10-18-2024, 05:19 PM
  • johnbeton
    Asus X415EA not charging battery
    by johnbeton
    I have an Asus X415EA board that is not charging the battery after some liquid damage. Everything else works, except charging the battery.
    So far I measured all the pins on the bq24780s controller with the following result:
    1. ACN = 0.0V
    2. ACP = 19.02V
    3. CMSRC = 18.5V
    4. ACDRV = 23.9V
    5. ACOK = 5.9V
    6. ACDET = 2.57V
    7. IADP = 0.17V
    8. IDCHG = 0V
    9. PMON = ?
    10. PROCHOT = 5.05V
    11. SDA = 3.3V
    12. SCL = 3.3V
    13. CMPIN = 0.47V
    14. CMPOUT = 6.0V
    15. BATPRES = 0.0V
    16....
    05-19-2025, 04:05 AM
