Dell P2720DC - Powers on only in test mode
  • CornholioGSM
    • Feb 2014
    • 265
    • CZECH
    Hello
    I have Dell monitor P2720DC.
    Monitor powers on without problem, but shows only panel test - WRGB filled display - and i am unable to exit this mode...buttons does nothing.
    Is here any fix for this?
    Maybe reprogramm SPI with working img ?
    Monitor board is 715GA309-M02-000-0H5I
  • Borse2008
    by Borse2008
    • There’s
    07-15-2025, 04:55 AM
  • Bowline
    by Bowline
    06-11-2025, 10:13 AM
  • DanPoka
    by DanPoka
    02-15-2025, 05:05 AM
    by momaka
    03-15-2023, 10:17 PM
  • Chivo77
    DELL LATITUDE 5420, ST 20TFKN3, LA-K491P REV:2.0 (A01) powers on and die about 15 secs later, no video
    by Chivo77
    hello friends, I have a DELL LATITUDE 5420---MODEL P137G, ST 20TFKN3 LA-K491P REV:2.0 (A01) and its quite a challenge. It powers on with the battery disconnected, lasts on for about 15 secs, and then shuts off. It does the same with battery only (no adapter). With battery and adapter it sometimes starts after hitting the button several times. It displays nothing in every case. Since only the Boardview is available, I guided myself with schematics similar to this laptop (I'll add them down).Some measurements:
    1- After receiving power SIO_SLP_S0# goes high and never changes.
    2-every...
    07-03-2025, 09:20 AM
