LG 34 GN73A
  • crazycavan
    • Sep 2022
    • 16
    • paris
    LG 34 GN73A
    LG 34GN73A screen with horizontal lines the menu is not clear, I tried to put tape on the lvds cables nothing
    motherboard power supply EAX69765701 (1.1)​
  • yoxardas
    YoXarDaS
    • Jul 2015
    • 4
    have you measured voltages on all inductors?
    • lotas
      • Jan 2016
      • 4642
      • Russia
      The problem is in the panel, try disconnecting the cable and look at the image on half the screen, the defect with stripes will disappear....
        LCD LED TV Service Menu Codes
        ALL LCD LED TV SERVICE MENU CODES
        Service Menu Code with Board Name
        China Universal Board / Jumper Board Service Menu Code
        Changhong Ruba Service Menu Code
        Ecostar LED TV Service Menu Code
        Orient LED TV Service Menu Code
        Haier LED TV Service Menu Code
        TCL LED TV Service Menu Code
        Samsung LED TV Service Menu Code
        LG LED TV Service Menu Code
        Videocon LED TV Service Menu Code
        Supra LED TV Service Menu Code
        Toshiba LED TV Service Menu Code
        Symphony LED TV Service Menu Code
        Veste/ LED TV Service Menu Code...
        10-31-2024, 03:58 AM
      • howardc64
        by howardc64
        Problem
        08-04-2024, 10:36 PM
      • RetroComputingGrotto
        IBM LTO 7 Tape Drive - Dust Sensors??
        by RetroComputingGrotto
        I have a Quantum SuperLoader robotic tape library that uses an IBM LTO 7 tape drive which is constantly complaining that it needs cleaning. If you insert a cleaning tape, it performs the clean and resets the cleaning counter to 0 hours. It should only require cleaning every 50 or so working hours but after as little as just 1 hours use it requests cleaning. We've purchased a new cleaning tape along with new LTO backup tapes but that has not resolved the problem.
        I have taken the library apart and can see no noticeable signs of dust inside. I have removed the tape drive from the...
        09-19-2024, 01:54 AM
      • vf fa
        EIZO CX270 - No signal but Backlight and Panel works, logo works, admin menu works. OSD doesn't. What?!
        by vf fa
        Hi, so i guess I´ll have to make a new topic here, as i browsed through hundreds of other threads but couldn't find a solution to my problem yet.
        I got a EIZO CX270 from a friend. He said it doesn't work anymore and wont display any signal or take any OSD inputs. Well, as an aspiring photographer I couldn't say no, could I? Thought it was an easy game, replace a bad cap and have a working monitor. But nooope, it wasn't supposed to be this easy.
        So let me start with the problem description. I'll try my best not to skip anything so this might get rather long.
        01-31-2024, 01:40 PM
      • triplefour
        LG 75UN8570AUD panel issue fixed with tape.
        by triplefour
        I've been seeing a lot of the new TVs (samsung and LG only i think) maybe 1-2 years old suffering from sudden panel death and have been over 50% successful bringing them at least most of the way back to functionality if not all the way, with the tape masking of the LVDS pins method.
        add this one to the list. the issue was on the left side of the panel and i ended up blocking just 3 pins on the connector that joins the two panel boards that make up the left side of the panel (it has 4 boards total) i didnt get the picture back to 100% perfect. i spent hours fiddling with which pins to block...
        07-17-2023, 10:22 PM
