Philips 105S5 horizontal issue
  • keyboardcowboy
    • Apr 2006
    • 73
    Adjusting PINCUSHION settings is having no effect on the monitor.A friend of mine suggests that one of the component attached with the silver heatsink in the picture below is responsible
  • keyboardcowboy
    • Apr 2006
    • 73
    Re: Philips 105S5 horizontal issue
    doesn't anyone knows how to fix this problem?
    • ovrax
      Philips 55PUS6804/12 turn on & off (probably backlight issue)
      by ovrax
      First of all, please excuse me as I'm quite new to this field.
      I have a Philips 55PUS6804/12 TV. It turns on and off instantly (backlight flash). I personally think it's a backlight issue (faulty LEDs). Could you help me confirm my diagnosis?
      I've checked and the T-CON seems to be fine. I disconnected one ribbon cable at a time at the bottom, but the problem persists.
      The Ambilight works perfectly and stays on.
      No sounds.
      Thanks in advance.
      08-25-2024, 04:33 AM
    • charlesdutcher
      No picture issue in Philips Chassis FTL2.1
      by charlesdutcher
      My Plasma Philips 37inch chassis FTL2.1 does not show picture. It automatically goes into protection mode after 30 seconds (red led blinks at 3Hz)
      Is there someone having any symptom like this? How to fix it?
      Thanks in advance!​
      08-06-2024, 09:55 PM
    • celiabrown
      Issue with Plasma Philips 37inch chassis FTL2.1
      by celiabrown
      Hello guys,
      My Plasma Philips 37inch chassis FTL2.1 does no picture ,and goes into protection mode after 30 seconds (red led blinks at 3Hz).
      Can someone has any symptom like this ?
      Thanks​
      05-09-2024, 10:56 PM
    • betmen
      TV Philips 43PUS8505/12 - horizontal line and picture jumping
      by betmen
      TV is Philips 43PUS8505/12, bought in 12/2020, so the two-year warranty has expired about 5 mounth ago...
      Problem is that 15 minutes after TV is turned on, the horizontal lines appear and picture start jumping up and down.
      I suspect that T-CON is faulty when wormed up...
      I separated all the cables from the T-CON and cleaned them but there is no change.
      Eco mode is disabled, software is up to date, I make factory reset and reinstal TV from TV menu...no change, problem is stil here.
      Anibody have some thoughts?...
      05-30-2023, 10:19 AM
    • DoOm86
      philips 55pft5500/12 Backlight issue. What am I doing wrong?
      by DoOm86
      TV philips 55'' no backlight (image ok).
      I tested the backlight with my led tester from the unplugged connector cable and it lights up. I had voltages at the motherboard connector, but anyway I order a new psu. Same problem, same voltages. Disassembled the TV and checked every strip with my led tester, they all light up, same voltage for every pair of strip (they go two by two).
      What am I missing?
      And something else I don't understand. I checked and I have 3v Leds, 10 per strips. Why every pair of strip (so 20 Led) take about 32v when powered up with my led tester 🤔
      04-16-2024, 03:47 PM
