2 Sec to black strange problem
  • artoodeestu
    • May 2014
    • 13
    Hi guys,
    Just to preface this, I've read and followed the sticky guide on this.
    I've got a samsung Syncmaster 2443BW, and it had the 2 sec to black issue. I replaced most of the caps, and it worked fr about 2 and a half hours before reverting back to 2 sec to black.
    Anyone know why this happens, and if there is a fix for it?
    Stu
  • viziks
    • Mar 2012
    • 33
    • India
    Re: 2 Sec to black strange problem
    Check the Inverter transformers,there may be variation between the resistance readings of primary windings of both Inverter transformers.
    Samir
    • artoodeestu
      • May 2014
      • 13
      I'm relatively new to this stuff, so how would I go about doing that?
      Heres a few pictures of the board.
      http://imgur.com/a/m9WPa
      • redwire
        Onkyo TX-SR607 HDMI problem showing a black screen intermittently
        by redwire
        Onkyo TX-SR607 HDMI problem showing a black screen intermittently, audio was OK.
        It would usually cut out a few minutes after power on, for maybe 1 minute then work OK, then cut out and go to black again. Or fade out to sparkles and noisy video.
        Well known is these boards need recapping and there is a strange mix of parts on both sides of the board.
        The bottom of the board has 100uF 4V (5.3*5.3mm, qty 5) and 220uF 4V (6.6*6.6mm, qty 5).
        Per the service bulletin, an issue is the Toshiba LDO's want low ESR for stability so I went with 100uF 6.3V polymer...
        11-16-2023, 08:56 PM
      • theone111
        by theone111
        3. Problem: TV shuts down
        07-22-2024, 10:36 AM
      • String2016
        Acer Predator PH315-52 no display/black screen problem - need working bios please.
        by String2016
        I need a working bios on this acer predator
        MODEL:ACER PREDATOR PH315-52 54KC
        S/N:NHQ54SP00A024028992600
        SNID:02401039326
        Attached is the original bios no display problem black screen keyboard lights on...
        10-10-2023, 06:00 PM
      • dudochnicht
        Dell Inspiron 7520, LA-8241P mainboard problem, power on black screen
        by dudochnicht
        Hi, i have a Problem with my Dell Inspiron 7520 LA-8241P Mainboard.
        When i start it, all LED's turns on but the display is black.
        Shortly after starting I noticed a click on the mainboard but don't know where it came from.
        I have tested it with the i5 and after the click the laptop goes off but with the i7 the laptop stays on after the click .
        The Dell Inspiron 7520 supports the i7
        What I've already done:
        - start without RAM and it beeps 2 times
        - start without bios battery and it beeps 5 times
        - Press D on start,...
        10-24-2021, 06:43 AM
        HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
        This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
        09-12-2024, 02:00 PM
