Inverter Transformer??
+ More Options
Posts
  • Jerryv
    • Oct 2012
    • 22
    Has anyone had any luck substituting inverter transformers? I have an Asus VW246H that developed a backlight problem. Couldn't find a schematic, but didn't see anything obviously wrong with the power supply. Using a test lamp on the four lamp outputs, I found that one of them was weak. It would only light a couple of inches of the tube. I suspected the inverter transformer might be bad, but resistance readings were consistent. (1040 ohm secondaries) After checking a few more things, I swapped the two transformers and found that the problem followed. Further examination of the bad one revealed an arcing problem on one of the windings shown in the attached picture.
    The p/n on the transformer is 1J.26061.021 and I have not been able to locate one. Not having the specs other than the measured secondary resistance, I am not sure how to proceed. Any suggestions?
    Jerry
  • mancaveman
    • Aug 2012
    • 8
    • Hungary
    Re: Inverter Transformer??
    Someone on eBay has a few of them. Might we worth a shot.
    A search for the part number should turn it up.
    • Jerryv
      • Oct 2012
      • 22
      Thanks I didn't see them earlier when I searched. Got one on order.
      Jerry
      • caseyjay_48
        Sony KDL-46BX450 Inverter Troubleshoot Logic
        by caseyjay_48
        I am currently on a troubleshoot of 46” Sony KDL-46BX450 tv. I came back from Washington to Texas on medical emergency and had to leave all my tools up there. All I have is a couple of screwdrivers and a dvm. I wish to ask the community a troubleshooting question. Please forgive stupid questions as meds I am taking produce brain fog.
        I have well maintained Sony KDL-46BX450. It went black one day. After turn-on, I get solid green light and Sony logo in screen center for about 1-2 seconds, then black. No blinking LEDs, no hissing. Flashlight test shows screen characters dimly viewable,...
        09-23-2022, 08:08 PM
      • amelbye
        is it ok to replace a dual output transformer with two single output transformers?
        by amelbye
        Hi, some prestory: I was repairing an amplifier - a "Phil Jones Bass". It had some bad capacitors an a faulty power switch. Easy job. However upon putting it back together I screwed up. The connector from the 15V-0V-15V from the transformer is identical to the audio ouput from the preamp board to the poweramp board. I ended up putting +-15VAC into the preamp outputs frying some traces on the circuit board along with the power transformer The transformer is shorted. It blows the fuse immediately even with no load on the secondary.
        Now that's a challenge - luckily...
        08-21-2020, 08:51 AM
      • ohren
        Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
        by ohren
        Hello!
        I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
        Measured voltages with no load:
        After rectifier diodes
        12V: 6.17 V
        5V: 5.67 V
        Secondary transformer pins AC measurement (really don't know if this says anything)
        12V: 2-2.5 V
        5V: 1.04 V
        I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
        03-18-2023, 10:33 AM
      • JFarm
        Sharp Aquos LC-46E77UN inverter testing
        by JFarm
        I picked this TV out of a trash pile. When I plug it in I can hear the relay on the power supply “click” almost immediately, and then 7 seconds later there is another “click” and the power/OPC LEDs start to flash: two pulses on the power LED, one on the OPC LED. I didn't notice any sign of life from the backlight, but more on that below.....
        The service manual () says this is a “DET_10V error: UR10V or A9V is not applied”, but after checking several voltages I believe the power unit is tripping off due to an overload as soon as the backlight tries to come on; this kills...
        03-21-2021, 11:10 AM
      • mikey5791
        Is it possible for transformer substitution?
        by mikey5791
        Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
        Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
        My questions are
        1. How do i test to see if the transformer is in good working condition?
        2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
        Hope you guys understand what i was asking. My intention is...
        11-03-2022, 02:11 AM
