compaq q2159 going into standby
  • jwilliams1967
    • Apr 2014
    • 54
    Hi everyone. This is my first post so I apologise if Im in the wrong forum.
    The problem I have is this monitor only displays a picture when I first power it on and then when it boots into windows. The picture lasts for a second then goes black. if I switch off and on again I get a picture for a second then if goes off again. the same happens if I unplug the vga cable. there is no picture at all so I think the 2 seconds to black is not the problem. I have visually checked for bad caps and dry joints . I have followed the 2 seconds to black as described in this forum although ,as I have stated , I don't think this is the problem because I have no picture at all. please help.
    many thanks
  • Rtech
    • Jul 2010
    • 1095
    Re: compaq q2159 going into standby
    If you get a Picture and then it goes off, the two most likely faults are the Backlights,be it the lamps or the wiring on one of them or more...OR a failed Inverter transformer.Photos are the 1st requirement for more help...use 'Go advanced ' below then manage attachments.
    • rauno45
      • 48
      • Estonia
      When my benq monitor showed similar symptoms it turned out to be one of the transistors shorted and because of that the power supply shut itself down after a few seconds so that it could not hurt any other components on the board. Maybe you should check for shorts on the board. But if you would have pictures it would help to troubleshoot a bit.
      • jwilliams1967
        • Apr 2014
        • 54
        will post pics in a minute
        • jwilliams1967
          • Apr 2014
          • 54
          Here are the photos as requested. I have followed the guide 2 seconds to black to the best of my ability but as I have stated ,I don't think its relevant because I cannot see a picture when I shine a light on the screen. ( im a computer engineer and have seen inverter problems many times before).
          If the monitor is left on for a while then the screen goes into standby as would be expected . strangely every time I shut the pc down and restart I get a brief picture at the startup screen and also when it first boots into windows. I have tried this monitor on other pcs so am certain its not a pc issue.
          please help people .
          • philliesfan30m
            • Aug 2013
            • 542
            i'm gonna have to agree with rtech as it being a bad bulb probably sending it into shut down mode or inverter problem. what voltages do you have on the 10 pin connector on the power board with power on and off?
            • jwilliams1967
              • Apr 2014
              • 54
              thanks for the quick response . will check in the morning and post results.
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4477
                • Italy - Milan
                I've never heard this type of problem, it always hear one new..
                Check the voltage of the 2 voltage reg. U101-U102 on video input board, report the part. numb. and pin readings.
                • jwilliams1967
                  • Apr 2014
                  • 54
                  Hi guys . im a bit of a novice so can you give me some quick guidance please
                  When measuring the voltage on the 0 pin connector what should I set my multimeter too ? ac or dc and what range ? and can I use the metal chassis as an earth reference point or would one of the black wires on the terminal be earth. many thanks for your patience
                  • jwilliams1967
                    • Apr 2014
                    • 54
                    worked it out people . set meter to 20v dc and last 2 blacks are earth . will post results as requested by philliesfan0m
                    • jwilliams1967
                      • Apr 2014
                      • 54
                      hi here are the results from the 10 pin connector working from the red wires down to the green on and in standby.
                      monitor on
                      5.06
                      5.05
                      0
                      0
                      3.6
                      2.83
                      3.21
                      2.53
                      2.48
                      0
                      monitor in standby
                      5.06
                      5.05
                      0
                      0
                      0.09
                      3.03
                      2.51
                      2.48
                      2.48
                      0
                      hope this makes sense to somebody.
                      thanks again
                      • philliesfan30m
                        • Aug 2013
                        • 542
                        what are all the pins labeled on the board if they are labeled. pin 5 looks to be the ps_on signal from the main board.
                        • Lumberjack777
                          • 464
                          With your symptoms and not being able to see a picture at all. I'd check the voltage regulators on that main board.
                          Retiredcaps wrote an excellent guide on how to test those. https://www.badcaps.net/forum/showth...tage+regulator
                          Also, this youtube is excellent from norcal715 - http://www.youtube.com/watch?v=cNFzBJELFoU
                          • Rtech
                            • Jul 2010
                            • 1095
                            When you have these symptoms,and carried out the '2 secs to Black',you decided that this was not the problem, as you could not see any image on the screen.....in some cases that is quite normal,but still the problem is '2 secs to black'. You can switch it on and off ?? you do get an initial image ?? it looks from your voltage readings that the 5v is fine, and if the on/off voltage eluded to by Philliesfan is the Enable/Backlight On,then in my opinion the problem is on the power supply Board or Backlights/Backlight wiring.
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4477
                              • Italy - Milan
                              Your pin readings seems correct, what do you get on that "not connected" 11th and 12th pin visible on the bottom side?
                              • jwilliams1967
                                • Apr 2014
                                • 54
                                hi davi.p can you tell me exactly where 11th 2th connectors are please
                                • jwilliams1967
                                  • Apr 2014
                                  • 54
                                  Here are the results from metering the voltage regulators.
                                  pin 1 is labelled on the board
                                  U101 LD 1117A 33AVE
                                  pin1 0
                                  pin2 3.27
                                  pin3 5.06
                                  U102 AS 1117L-18
                                  pin1 0
                                  pin2 1.79
                                  pin3 3.26
                                  thanks for all your help people. learning a lot and enjoying it
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4477
                                    • Italy - Milan
                                    the first readings you've made are on the output connector, if you watch on the bottom side there are 2 contacts for the same connector made for a larger connector, at the 11th + 12h pin you have to measure something from 12 to 24 v, but this don't reveal much i think. I notoce now that in the title you said "goint to st.by" why? Unfortunately your Video input board (VIB) has good regulators, so i think you have a bad vib.
                                    • jwilliams1967
                                      • Apr 2014
                                      • 54
                                      the monitor goes into standby because of power management settings . it is behaving as it should but has no display or backlight. what is vib?
                                      • jwilliams1967
                                        • Apr 2014
                                        • 54
                                        sorry ignore last question
                                          HP Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) Compaq Elite 8000 E5500 Specification for Upgrade or Repair
                                          This specification for the HP Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) boardview and Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request...
                                          09-12-2024, 03:44 PM
                                          HP Compaq Compaq SG3-240ES Compaq SG3 220 Specification for Upgrade or Repair
                                          This specification for the HP Compaq Compaq SG3-240ES can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq SG3-240ES boardview and Compaq Compaq SG3-240ES schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          HP Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower Compaq Pro 6005 B59 Specification for Upgrade or Repair
                                          This specification for the HP Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower boardview and Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information....
                                          09-12-2024, 03:36 PM
                                          HP Compaq Compaq SG3-331IT Compaq SG3 245 Specification for Upgrade or Repair
                                          This specification for the HP Compaq Compaq SG3-331IT can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq SG3-331IT boardview and Compaq Compaq SG3-331IT schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-12-2024, 03:30 PM
                                          HP Compaq Compaq dc7900 Compaq Q9400 Specification for Upgrade or Repair
                                          This specification for the HP Compaq Compaq dc7900 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq dc7900 boardview and Compaq Compaq dc7900 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
