Black Screen Dell E1910Hc 19" LCD
  • dig29089
    • Sep 2012
    • 19
    • Saudi Arabia
    Can you please help me on how to troubleshoot this monitor?
    When I connected the power, there's a blue power led indicator but the screen is black only and there is no display or shadow picture.
    I tried to open and I did not see any busted electrolytic capacitor, I tried to search first on the internet and what I found as the same model with my monitor to replace the electrolytic capacitor.
    I replaced all the capacitor but I don't have the same voltage rating, what I do is, I used 680uF 35V as replacement for 680uF 25V and 470uF 25V as replacement for 470uF 16V, the voltage rating become higher but the capacitance are all the same.
    When I tried to power on again it is still the same symptoms, blue led indicator and black screen.
    See the attached actual pictures...
  • Rtech
    • Jul 2010
    • 1095
    Re: Black Screen Dell E1910Hc 19" LCD
    Check D902 and D907,would be my first option.If they are Ok then I would piut the whole thing together,apply a Pc Signal and ensure that you can measure approx 3volts DC on C902 Blue (-) and Black (+).OR>>you can Power up the Power Board ONLY, being very careful,and put a 1k resistor betwen the 5v and Gnd on C902,and with the Backlights ONLY connected see if they illuminate.
    • dig29089
      • Sep 2012
      • 19
      • Saudi Arabia
      Rtech,
      D902 = 0.435
      I cannot find D907 on the board, I measure these two diodes:
      D901 = 0.422
      D905 = 0.435
      CN902 = Blue/Black = 3.2Volt
      • Rtech
        • Jul 2010
        • 1095
        The diode on the heatsink next to C904..probably a Schottky diode ??.If that is ok measuring from the centre pin to the outside legs, then it looks to be probably the Inverter transformer and/or a Backlight fault ...You need some test backlights ??
        • dig29089
          • Sep 2012
          • 19
          • Saudi Arabia
          I saw it, D907 = SRF1060 Schottky Rectifier, I tried to test using digital multimeter set to diode, from center-right (2-3) = 0.143V; from center-left (1-2) = 0.144V
          thanks
          • dig29089
            • Sep 2012
            • 19
            • Saudi Arabia
            how can i test the inverter transformer using digital or analog tester?
            thanks
            • Agent24
              I see dead caps
              • Oct 2007
              • 5096
              • New Zealand
              thanks
              Normally you could compare winding resistance but if your board only has one transformer there is nothing you can compare it to, unless you find the model number of the transformer online and find what the resistance is supposed to be.
              -David VanHorn
              • Rtech
                • Jul 2010
                • 1095
                As Agent 24 noted,that is the only way.But as I suggested spare baxklights for test would certainly confirm or not if they are the problem...which I think it probably is.
                • dig29089
                  • Sep 2012
                  • 19
                  • Saudi Arabia
                  You means guy we cannot conclude if the transformer is bad or good on testing it using multimeter?
                  @rtech
                  how can I test the backlight? this backlight is the one inside the LCD?
                  thanks guys
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 5096
                    • New Zealand
                    You could try this: https://www.badcaps.net/forum/showthread.php?t=19987
                    If you don't have a spare CCFL lead you can cut up, you could probably just solder some wires to the underside of the connector's pins on the board.
                    PS: Anyone else notice the weird white IC901? I have never seen an IC like that before!
                    -David VanHorn
                    • rtstorm
                      • Feb 2012
                      • 971
                      • Croatia
                      did you try to turn off the lights in room and light the LCD display to see if there is a picture? Maybe monitor works but you dont have a backlight only
                      ...the quieter you become the more you are able to hear...
                      • dig29089
                        • Sep 2012
                        • 19
                        • Saudi Arabia
                        @rtstorm,
                        there is no picture or shadow on the screen when I used a flash light or turn off the light in the room.
                        • HTR-Informatique
                          by HTR-Informatique
                          02-09-2025, 06:51 AM
                        • Swedishpower
                          Dell G3 15 3500 black screen
                          by Swedishpower
                          Hello
                          I have search everywhere for a solution for my problem, but cant find it anywhere.
                          When I was away to trow some garbage i always look in the electronic bin.
                          and this time i find a laptop.
                          Dell G3 15 3500, when I get home i look at the battery, add one harddrive, plug in the powercord.
                          the lamp for charmig is white.
                          Tryed to start it, the screen blink for a second, the keyboard lightsup, the fans and HD starts.
                          but no Dell logo.
                          I tryed with a hdmi cable to another screen, still black.
                          I started to search solution and tryed...
                          07-06-2025, 06:18 AM
                        • hcinne
                          Dell G15 ryzen edition black screen 2 amber 1 white
                          by hcinne
                          I have a Dell G15 ryzen edition (ryzen 5) that turns on but won't post, black screen, keyboard lights on, caps lock led on, fans turns and the battery indicating light is showing 2amber and 1 white according to dell website it's a cpu failure, but i tried few basic things before i open it up i tested the screen by pressing the d button before powering it up but it didn't show anything i tried the ctrl+esc for bios recovery but still black screen i tried refreshing the screen, i plugged it on an external monitor but same thing. Next step i unplugged the battery and kept pressing the...
                          07-23-2024, 07:56 AM
                        • jake-b
                          dell e6540 boots to black screen (no dell logo)
                          by jake-b
                          good morning all,
                          i purchased a used dell e6540 laptop used 10 months ago from a vendor on ebay. intel i-7 processor, 16 gb ddr3 memory, 256 gb ssd., mobo la-9413p (rev 1.0 dated 2014-08-04). i've inflicted no damage on it since purchase but its past is unknown. starting 2 weeks ago it began to fail to boot (initially 9 of 10 boot attempts failed, now 10 of 10 fail). there was no new hardware or software added (i was using as a kodi video server). the post process doesn't complete and booting no longer displays the dell logo screen - screen remains black with no backlight. some other...
                          01-08-2024, 10:29 AM
                        • howardc64
                          by howardc64
                          Problem
                          08-04-2024, 10:36 PM
