Dell 2007 FPb went black all of the sudden.
  • Fud
    • Mar 2009
    • 62
    Before this I noticed sometimes a very very slight flicker that would go away then one day blam just black. I thought it might be the backlight or something. So after taking it apart it has 4 boards, the PSU all the caps looked fine but two of the others had slightly buldging caps from a brand called Elite which i never saw before. all the bulging ones are 24v, I'm wondering if it's even worth fixing something that old to resell and messing with it for ages. From what i heard Dell doesn't send out extra boards or stock them. So i counted about 8 or so caps that looked suspect. Would someone here go sure it's worth it just order new better caps and see if that is the only problem or just scrap it?
    On edit the rest are perfectly flat on top and no signs of failing but there are a ton of them would it just be better to pick out the visible bad ones instead of the tedious task of doing them all which someone that doesn't do it all the time isn't a breeze like a pro.
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Re: Dell 2007 FPb went black all of the sudden.
    Elite looks like crap! Had a bulging Elite cap in a PSU of a 2003 Dell Dimension 2350 (Has Pentium 4 Northwood 2.2 Ghz) that just had light use. Was mostly idle!
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • HTR-Informatique
      Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
      by HTR-Informatique
      YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
      I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
      On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
      I also changed the screen because the PC fell and the screen was broken.
      I changed the battery with a new and original battery.
      I also had corrosion/oxidation on the...
      02-09-2025, 06:51 AM
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • jake-b
      dell e6540 boots to black screen (no dell logo)
      by jake-b
      good morning all,
      i purchased a used dell e6540 laptop used 10 months ago from a vendor on ebay. intel i-7 processor, 16 gb ddr3 memory, 256 gb ssd., mobo la-9413p (rev 1.0 dated 2014-08-04). i've inflicted no damage on it since purchase but its past is unknown. starting 2 weeks ago it began to fail to boot (initially 9 of 10 boot attempts failed, now 10 of 10 fail). there was no new hardware or software added (i was using as a kodi video server). the post process doesn't complete and booting no longer displays the dell logo screen - screen remains black with no backlight. some other...
      01-08-2024, 10:29 AM
    • Swedishpower
      Dell G3 15 3500 black screen
      by Swedishpower
      Hello
      I have search everywhere for a solution for my problem, but cant find it anywhere.
      When I was away to trow some garbage i always look in the electronic bin.
      and this time i find a laptop.
      Dell G3 15 3500, when I get home i look at the battery, add one harddrive, plug in the powercord.
      the lamp for charmig is white.
      Tryed to start it, the screen blink for a second, the keyboard lightsup, the fans and HD starts.
      but no Dell logo.
      I tryed with a hdmi cable to another screen, still black.
      I started to search solution and tryed...
      07-06-2025, 06:18 AM
    • hcinne
      Dell G15 ryzen edition black screen 2 amber 1 white
      by hcinne
      I have a Dell G15 ryzen edition (ryzen 5) that turns on but won't post, black screen, keyboard lights on, caps lock led on, fans turns and the battery indicating light is showing 2amber and 1 white according to dell website it's a cpu failure, but i tried few basic things before i open it up i tested the screen by pressing the d button before powering it up but it didn't show anything i tried the ctrl+esc for bios recovery but still black screen i tried refreshing the screen, i plugged it on an external monitor but same thing. Next step i unplugged the battery and kept pressing the...
      07-23-2024, 07:56 AM
