So I have been spending the last 24 hours trying to figure out how to fix my monitor instead of having to buy a new one. I have done a little research, but need some clarification on things. Keep in mind, this is all very new to me and I am learning as I go. I have some experience with electricity and circuit boards from growing up, but I have forgotten most of it.
The symptoms -
When I turn my monitor on, it shows a great picture for 2 seconds and then the backlight goes out. It does this over and over again. I am able to see the screen when I shine a light on it, so it is obviously power/light.
What I have done -
1. I first tried turning the brightness down as some have said this helps. This didn't work for me.
2. I have taken the monitor apart and have removed and or tested the electrolytic capacitors and all seem to be reading at their expected level.
3. I put the power board back together and into the shell of the monitor and plugged it in and made it a live circuit, without the screen hooked up. I tested the voltage at various places and found that at the connections for the screen cables, the voltage spikes from 0V to anywhere between 20-30V when I start the monitor (or change inputs) and then drops back to 0V after 2 seconds. So I think it is safe to assume that there is a problem on my board and this is why the backlight is going out.
My questions -
Can capacitors see a voltage drop? I notice some of the ceramic capacitors drop the voltage from 120V to 0V or 68V to 0V in various places. I tested some of them and they seemed normal, so I assume this normal in a live circuit.
The reason I ask this is because I tried tracing the power backwards from the cable connections, while turning the power on or switching inputs, and noticed that one of the electrolytic capacitors was fluctuating from 0V to 3V on its positive side, but was showing nothing on its negative side. So with my limited knowledge, that made me think that the power is not getting through. However, the reason I am doubtful is because I checked the capacitance of this particular one out of circuit and it seemed fine. Does this make sense? Is this possible?
In the pic -
The BLUE boxes are ceramic capacitors that see a drops to 0V. Top top one 68V to 0V and the bottom left one 120V to 0V.
The RED box is the electroyltic capacitor that fluctuates from 0V to 3V on the positive side, but sees no voltage on the other side.
The YELLOW boxes are the transformers, each pin sees the spike when the monitor is initially turned on, but then drops to 0V
The WHITE boxes are where the connections for the backlight cables are and see the spike to 20V+ when the monitor is initially turned on.
Any help is greatly appreciated.
					The symptoms -
What I have done -
My questions -
In the pic -
						 . I do have a multimetre. I have read the posts above, I'm quite a newb. but Im determined to fix it and get a free monitor, cause it was given to me
