samsung 2494LW 2-3 sec cclf light off
  • majkstone
    • Feb 2011
    • 7
    Hello new in the forum hello to all.
    Read lots of post with 2-3 sec death on LCD monitors nbefore decide to make my post.
    So all caps are ok on
    trafo desoldered and mesuring resistance s1-s2=960ohm s3-s4=1080ohm
    ther is 13V 5V and 3.3V from inverter board here no problem.
    mosfets 4512 SMD 8pin try to test on board they are not in short but diff to check without desoldering (by measuring seem both ok also not overheating)
    I am shure i have problem with feedback current to the main IC1 chip from CFL lamps to IS (pin4) and FB and VS pin 3 and 5
    using this sch of BN44-00296 but my board is BN44-00297D
    Anyone have the inverter sch of the BN44-00297D please post will help alot.
    SO this are mesurements form BD9893F
    Pin 0n V 0ff V
    1 1.38 0
    2 1.35 0
    3 1.26 0
    4 1.24 0
    5 0.44 0
    6 0 0
    7 4.5 4.5
    8 1.4 0
    9 0.85 0.61
    10 1.9 0
    11 2.8 0
    12 1.8 0
    13 2.25 0
    14 0 0
    15 2.3 0
    16 9.3 9.44
    After while find solution to alter resistance from pin1 to gnd
    originally 33k+270ohm from pin1 to gnd remove 270ohm replaced with 10k trimmer monitor works...
    But after intense testing i get overheating of the four 56K resistors in serial (all together 224 kohm) connected on the sec of hi volt transformer beetwen s1 and s3, resistrs are in SMD
    Can i replace all them four with one resistor of 220 kohm about 1w or 0.5W?
    seems the problem is the difference more than 3% of the two secundars from hi voltage trafo for ccfl lamp am I right ?
    Any suggestion for a fix without replcement of the hi voltage trafo?
    Regards hope here soon from someone https://www.badcaps.net/forum/images/smilies/compy.gif
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: samsung 2494LW 2-3 sec cclf light off
    You are correct you will need to replace one or both of the inverter transformers.
    There is no fix.
      09-07-2024, 05:50 AM
    • Kaar3l
      Samsung QLED QE65Q7FNAT only standby light
      by Kaar3l
      TV: Samsung QLED QE65Q7FNAT
      PSU: BN4400940A
      MB: BN94-12832K
      I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
      09-24-2024, 01:35 PM
    • marcinq
      Samsung UE60KS7000 No Standby Light
      by marcinq
      I've got a problem with a Samsung UE60KS7000 that was given to me and said that there was a problem with the One Connect box but as I understand the TV should turn on even with the One Connect box disconnected (which it doesn't). There is no stand by light.
      I've disconnected the Main Board from the PSU and when connecting to mains the backlight turns on which suggests the PSU might be ok. I've measured the voltages out of the PSU and they seem reasonable (like the labels say). The main board has no obvious burns, there are no shorts on the power rails anywhere....
      05-26-2025, 11:36 AM
    • ChristianBr01
      LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
      by ChristianBr01
      I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
      The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
      What I already found is that the 12.8V are not an the connector to the main board connector to the power...
      04-23-2025, 01:48 AM
    • DXseekerMO
      Samsung UN65NU6900FXZA Stand-by light on but voltages on PS indicate TV should be on
      by DXseekerMO
      Hello everyone!
      Tonight I picked up a Samsung UN65NU6900FXZA with a curious issue.
      Symptoms:
      1) Plug TV in to AC outlet, stand-by light illuminates briefly and goes out.
      2) TV does not appear to turn on
      3) Backlights do not illuminate, voltages associated with backlights on Power Supply are not present
      4) "Power on" terminal on Power Supply has 3.26v
      5) "A13V" terminals have 12.9v
      6) Stand-by test jumper on Power Supply has 12.9V
      7) Optical audio jack on Main Board illuminates
      8) With stand-by...
      06-09-2021, 12:19 AM
