I am quite surprised there s no thread yeat about this wonder, I got quite a few of them already. Always blown caps, sometimes it takes down fuse and inverter transistors.
You can get some images here http://diit.cz/clanek/fujitsu-siemens-scenicview-p19-2, that is the first one I repaired. It was already serviced with transistors before, they used bad caps so I recapped that. You can also see the input cap was getting bad. Sicne than it was usually just caps, sometimes fuse.
Now I got one more stubborn, also with input cap vomiting insides out. After recap, it seems there is more problems on primary than just the capacitor. Transistor and freewheeling diode measure good but I still do not have Vdd for the SG6841 PWM controller. Vin/pullup pin is OK with 3 V but I got nothing else but some 0,8 V at Vdd. Both the diodes there (one diode as rectifier with cap and than probably zener with another smooting cap) seem to be OK so this leads me into thinking the transformer is bad, either the main winding or auxiliary winding for the PWM controller.
Is there anything I can try to have a look at before high-voltage O-scope probe I have already ordered will come so I can scope the transformer than?
