Benq Q7C3
  • matthmal
    • Nov 2012
    • 306
    • Malta
    Benq Q7C3
    Hi guys,
    I have this Benq Q7C3 Monitor that had no power. I replaced the Bridge rectifier and also the fuse and it turned on.
    To my surprise it still didn't work, it started with a faded black display which started to turn into a white screen until it was completely white.
    Every time that I turn it on the same thing happens.
    I checked the C5707 transistors but none of them had a reading less than 50 ohms.
    Can someone please help me out?
    Thanks,
    Matt
  • matthmal
    • Nov 2012
    • 306
    • Malta
    Re: Benq Q7C3
    anyone please?
    • 1supertech
      • Apr 2012
      • 384
      Re: Benq Q7C3
      check the fuse on tcon make sure your lvga cable has good contact
      • matthmal
        • Nov 2012
        • 306
        • Malta
        Re: Benq Q7C3
        do you mean the fuse near the bridge rectifier? That fuse is good.
        The VGA cable is also good since it works with other monitors.
          Re: Benq Q7C3
          Fuse on the T-CON board which is part of the LCD panel assembly.
          http://s807.photobucket.com/user/bud...ml?sort=3&o=23
          • matthmal
            • Nov 2012
            • 306
            • Malta
            Re: Benq Q7C3
            Thanks for your post, I am not sure which one from my board is the fuse but I tested 5 components named: FB1; FB2; FB3; FB4 and FB5 and they all showed signs of continuity.
            Correct me if I'm wrong please
              Re: Benq Q7C3
              FB = FERRITE Bead, it is not the fuse. It should be something like F (Fuse)1 or CP (Circuit Protection)1.
              • matthmal
                • Nov 2012
                • 306
                • Malta
                Re: Benq Q7C3
                I can't find that fuse. Could it be that there are no fuses?
                • bomcla
                  • Nov 2010
                  • 16
                  Re: Benq Q7C3
                  check thes mosfet in the inverter FU9024N ! and 'success that face to the white screen to monitor. controls the condensers 0.22 between the C5707.
                  claudio from Italy !!
                  • jetadm123
                    • 2169
                    Re: Benq Q7C3
                    Perhaps you can post a photo of the tcon board?
                    • matthmal
                      • Nov 2012
                      • 306
                      • Malta
                      Re: Benq Q7C3
                      Sorry, I must have forgot to post the photos. Attached I am posting also zoomed photos.
                      Any comments?
                      • jetadm123
                        • 2169
                        Re: Benq Q7C3
                        Ah, a picture says a thousand words. What you're looking at is not the tcon board, but the main/logic board. The tcon board should be located at the top of the panel and span almost the width of the panel.
                          Re: Benq Q7C3
                          Scroll through the pictures in the link on post 5.
                          • matthmal
                            • Nov 2012
                            • 306
                            • Malta
                            Re: Benq Q7C3
                            I tried to search for the fuse as you showed me but I couldn't find it
                            • matthmal
                              • Nov 2012
                              • 306
                              • Malta
                              Re: Benq Q7C3
                              I only have two boards, the power board and the video board (T-Con Board).
                              • 1supertech
                                • Apr 2012
                                • 384
                                Re: Benq Q7C3
                                Tcon is on back of LCD panel sometimes it has a cover with three screws
                                • jetadm123
                                  • 2169
                                  Re: Benq Q7C3
                                  In post #11, first photo, I believe the leftmost connector should have a flat ribbon cable connected to it. Correct? At the other end of that cable should be the tcon board.
                                  • matthmal
                                    • Nov 2012
                                    • 306
                                    • Malta
                                    Re: Benq Q7C3
                                    Thank you bud, I figured out that that is the T-CON board. I found out what the problem is.... the fuses are fine but the connector where the ribbon cable fits in is damaged. When I press it with my finger the picture will come up.
                                    I attached some pictures for everyone's reference.
                                    Any clue where I can buy one?
                                    • 1supertech
                                      • Apr 2012
                                      • 384
                                      Re: Benq Q7C3
                                      I don't think they Tcon is replaceable
                                      • matthmal
                                        • Nov 2012
                                        • 306
                                        • Malta
                                        Re: Benq Q7C3
                                        Guys,
                                        Thanks for all those who have helped me, the monitor is now fixed.
                                        I did put a piece of plastic to make pressure on the connector. I then used duct tape to make it hold still.
                                        Thanks for everyone, I really learned a lesson from this and learned what is a T-CON board.
                                        Thanks guys
                                          MSI Prestige P65 8RF-456NL Creator White Notebook P Specification for Upgrade or Repair
                                          This specification for the MSI Prestige P65 8RF-456NL Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-456NL Creator White boardview and P65 8RF-456NL Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-06-2024, 07:46 AM
                                          MSI Prestige P65 8RF-442 Creator White Notebook P Specification for Upgrade or Repair
                                          This specification for the MSI Prestige P65 8RF-442 Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-442 Creator White boardview and P65 8RF-442 Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                          09-06-2024, 07:29 AM
                                          MSI Prestige P65 8RF-457BE Creator White Notebook P Specification for Upgrade or Repair
                                          This specification for the MSI Prestige P65 8RF-457BE Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-457BE Creator White boardview and P65 8RF-457BE Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-06-2024, 07:25 AM
                                          MSI Prestige P65 8RF Creator White Notebook P Specification for Upgrade or Repair
                                          This specification for the MSI Prestige P65 8RF Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF Creator White boardview and P65 8RF Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          MSI Prestige P65 8RF-445ES Creator White Notebook P Specification for Upgrade or Repair
                                          This specification for the MSI Prestige P65 8RF-445ES Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-445ES Creator White boardview and P65 8RF-445ES Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
