Samsung S24A350 Monitor - No Video Input Detected ("No Signal")
    I picked up this monitor from a local computer supply shop for £30, advertised as faulty. Thought it'd make a nice complement to my 24" iiyama on my desk. Full HD 24" LED monitor, stupidly thin design.
    I plugged it in and plugged a HDMI input into it but it just says no signal. On VGA it simply turns off the backlight after briefly flashing "Analog" in the corner.
    I downloaded the firmware update from Samsung's website here
    http://www.samsung.com/us/support/ow...oduct/S24A350H
    and ran the program. It updated the firmware (took about 5 minutes) and the monitor powered off. Turned it on and the monitor works perfectly!
    Amazing to think this almost got thrown away and it's so easy to fix. It runs off a 14V 2A power supply. I'm considering modding it to operate off a 11.1V LiPo battery which my model aircraft use. Will be interesting to fly (first person view) my aircraft with this in the field - 2ms update time!
    Re: Samsung S24A350 Monitor - No Video Input Detected ("No Signal")
    Video of "repair":
    https://www.youtube.com/watch?v=E9LoiDOTMOE
    • glutton4punishment
      Samsung monitor Installed 1 cap wrong, now menu button dead, "no signal detected" msg
      by glutton4punishment
      Samsung synchmaster 226BW.
      Before I replaced 5 caps, the screen was dim.
      Sometimes it wouldn't turn on.
      I opened it up, and found 4 bad caps in the pwr supply section.
      I unfortunately installee one backwards, i.e. wrong polarity.
      When I turned it on, I head a loud pop, and I quickly shut it off.
      The replaced caps are 3 860uF 25V's, and 1 330u 35V.
      One of the 860uF blew.
      I didn't have another 860uF at home, so I tried it with a 1000uF 35V cap (I remember the reading of the 1k uF cap was close...
      03-18-2023, 12:49 PM
    • sew333
      Pc shutdown, monitor flickered with no signal after 10 seconds
      by sew333
      My pc:
      10850K stock 4800mhz stock Kraken X73 good temps
      2x16 GB DDR4 GSKILL 3000mhz XMP
      Seasonic Tx-850 Ultra Titanium
      Gigabyte Rtx 3090 Gaming OC
      Aorus Z490 Pro Gaming
      1 TB SSD
      4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
      Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
      Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
      Power...
      02-22-2022, 10:27 AM
      09-07-2024, 05:50 AM
      by momaka
      03-15-2023, 10:17 PM
      09-06-2024, 11:40 PM
