Samsung S24A350 Monitor - No Video Input Detected ("No Signal")
    I picked up this monitor from a local computer supply shop for £30, advertised as faulty. Thought it'd make a nice complement to my 24" iiyama on my desk. Full HD 24" LED monitor, stupidly thin design.
    I plugged it in and plugged a HDMI input into it but it just says no signal. On VGA it simply turns off the backlight after briefly flashing "Analog" in the corner.
    I downloaded the firmware update from Samsung's website here
    http://www.samsung.com/us/support/ow...oduct/S24A350H
    and ran the program. It updated the firmware (took about 5 minutes) and the monitor powered off. Turned it on and the monitor works perfectly!
    Amazing to think this almost got thrown away and it's so easy to fix. It runs off a 14V 2A power supply. I'm considering modding it to operate off a 11.1V LiPo battery which my model aircraft use. Will be interesting to fly (first person view) my aircraft with this in the field - 2ms update time!
    Re: Samsung S24A350 Monitor - No Video Input Detected ("No Signal")
    Video of "repair":
    https://www.youtube.com/watch?v=E9LoiDOTMOE
    • glutton4punishment
      Samsung monitor Installed 1 cap wrong, now menu button dead, "no signal detected" msg
      by glutton4punishment
      Samsung synchmaster 226BW.
      Before I replaced 5 caps, the screen was dim.
      Sometimes it wouldn't turn on.
      I opened it up, and found 4 bad caps in the pwr supply section.
      I unfortunately installee one backwards, i.e. wrong polarity.
      When I turned it on, I head a loud pop, and I quickly shut it off.
      The replaced caps are 3 860uF 25V's, and 1 330u 35V.
      One of the 860uF blew.
      I didn't have another 860uF at home, so I tried it with a 1000uF 35V cap (I remember the reading of the 1k uF cap was close...
      03-18-2023, 12:49 PM
    • sew333
      Pc shutdown, monitor flickered with no signal after 10 seconds
      by sew333
      My pc:
      10850K stock 4800mhz stock Kraken X73 good temps
      2x16 GB DDR4 GSKILL 3000mhz XMP
      Seasonic Tx-850 Ultra Titanium
      Gigabyte Rtx 3090 Gaming OC
      Aorus Z490 Pro Gaming
      1 TB SSD
      4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
      Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
      Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
      Power...
      02-22-2022, 10:27 AM
      09-07-2024, 05:50 AM
      by momaka
      03-15-2023, 10:17 PM
    • Ellos
      Samsung s21 sim recognized but no signal
      by Ellos
      I'm just starting out with smartphone repairs and picked up a Samsung S21 to work on. Everything functions perfectly except there's absolutely no cellular signal. The SIM card is recognized, WiFi works fine, but zero network signal.
      I've tested my SIM in another phone and it works perfectly with good signal, so it's definitely the phone.
      From what I've read online, this issue is usually caused by the network chip needing to be desoldered and reballed since one of the solder balls might be cracked.
      I think I've located the SOC that...
      06-27-2025, 01:31 AM
