Dell 2005FPW LCD Monitor
  • fddizon
    • Sep 2011
    • 555
    • Philippines
    hi,
    im looking for a Dell 2005FPW LCD Monitor schematic diagram
    power board is at fault. busted regulator ic
    ic replaced already but still wont power up
    tia
  • Bowline
    by Bowline
    06-11-2025, 10:13 AM
  • DanPoka
    by DanPoka
    02-15-2025, 05:05 AM
  • artvandalai
    Help identifying voltage regulator on this concept 2 pm5 monitor pcb board?
    by artvandalai
    This Concept 2 rower pm5 monitor doesn't shut down. It keeps turning on and stays on after being turned off. I read on another forum by another user that replaced the same component to check the voltage regulator.
    The monitor should pull around 35mA when turned on and in shutdown it should drops to around 0.060mA. Any advice on finding the voltage regulator on this board to check if it needs to be replaced?
    11-05-2024, 07:38 AM
  • Jesus Coder
    Issues Reviving Old Dell 2408WFPb Monitor
    by Jesus Coder
    I have been having some difficulties reviving an old Dell 2408WFPb PC monitor that I received for free. When I first acquired it, the backlights of the display were on but alas no image was showing. After extensive research on the topic, I went ahead and purchased a new t-con board for the monitor. After installing the board, I was then presented with a new screen that was half black and half green (more so black). I have been unable to figure out what to do next as I have limited knowledge of display electronics. Might anyone on this forum have an idea of what may...
    06-25-2023, 02:33 PM
  • deep000
    Burned Voltage Regulator in Monitor – How to Identify and Repair?
    by deep000
    My computer monitor ASUS VP249H stopped working, and smoke came out of it.
    I opened it and found that a voltage regulator had burned out.
    The problem is that I can't identify its reference.
    I searched online for schematics or photos of similar boards that people are selling, but without success (no schematics, bad quality of the board or lack of the reference when it's a good quality 😅).
    How can I find its reference, and do you think it's repairable?
    Monitor: Asus VP249H
    Board reference: 0171 - 2271 - 6083
    09-08-2024, 01:13 PM
