1 thin horizontal line across Laptop lcd screen
  • scobie_21
    • Jul 2011
    • 144
    Hi I have a laptop lcd screen with 1 thin horizontal line across screen (red) is it possible to repair this or just replace the whole screen?.
    Input appreciated.
  • expert_vision
    • Jun 2013
    • 7
    Re: 1 thin horizontal line across Laptop lcd screen
    Well, I can think of a couple of reason for that behavior:
    - one pin of the ribbon cable went loose (cold solder joints), which are a pain to fix
    - a micro break in the LCD glass that cuts an entire line, or transistor inside the glass that activates the entire line, is dead -- can't be fixed
    - video card artifact - check if the external VGA output port shows the same line
    - the board that converts the analog video signal to digital is broken - diagnosed through elimination
    Basically, go to a service and ask them to test your laptop display on another board, and see if the problem persists.
      Probably driver chip on panel flex failed -- would need screen swapped.
      • lexwalker
        • Feb 2011
        • 307
        • Malaysia
        Input appreciated.
        Panel problem. Usually replace the whole panel.
        • leapius
          • Aug 2012
          • 60
          • uk
          Could be delamintation of the ribbon cable to the panel. Try gently squeezing around the edges where the line goes to and see if that affects it at all.
          • cubytus
            Samsung UN50TU8000FXZC shows thin horizontal green line when warm
            by cubytus
            Hi to all,
            I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
            I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
            Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
            01-10-2024, 01:26 AM
            HP Mobile Thin Client mt44 Mobile Thin Client 3JG86EA Mobile thin client Specification for Upgrade or Repair
            This specification for the HP Mobile Thin Client mt44 Mobile Thin Client 3JG86EA Mobile thin client can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the mt44 Mobile Thin Client 3JG86EA boardview and mt44 Mobile Thin Client 3JG86EA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
            09-06-2024, 06:50 AM
          • Kiberge
            Samsung LH82QENELGC/EN Help needed - Static line on screen
            by Kiberge
            HI guys!
            I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
            I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
            the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
            This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
            04-22-2024, 11:28 AM
          • Ryan.man
            by Ryan.man
            02-04-2025, 12:23 PM
          • kotel studios
            Samsung LC32HG70QQUXEN - vertical and horizontal stripes across the screen
            by kotel studios
            Just now my Samsung LC32HG70QQUXEN monitor gave up on me. On cold boots I get many vertical stripes going across the screen (see the attached picture). After it runs for 1-2 minutes those go away but there are horizontal stripes going across the whole screen no matter of the input and PCs I use. (couldn't take an picture of it since the image size goes to 20MB and the camera doesn't pick them up)
            In a video about a 27" monitor with an similar issue the guy removes one resistor and supposedly the entire monitor goes back to life? For sure this fix is only temporary....
            08-06-2025, 02:07 AM
