Samsung s23a300b
  • Smoooth
    • Jun 2017
    • 3
    Re: Samsung s23a300b
    just google SA300 firmware and DL it from samsung
    Found it. Tried it. It says the firmware is up to date. The monitor does not power on now... No lights at all.
    • CapLeaker
      Leaking Member
      • 8354
      you could take the eeprom out check it if it is still good, flash a new firmware to it and put it back in.
      also you could buy hopefully a preflashed eeprom put that in, or replace the whole board, or replace the monitor.
        09-07-2024, 05:50 AM
      • GeckoGreen
        Samsung service bulletin: need firmware file for PN63C550 TV
        by GeckoGreen
        I'm hoping someone with access to the Samsung GSPN can help me. I need someone with access to download a firmware file for my PN63C550 TV, as it will fix a problem per the Samsung service bulletin.
        You can reference Samsung bulletin #:ASC20130528001 and I need the [2D63]LOGIC.bin file please.
        The full service bulletin is linked here: https://www.avsforum.com/attachments...3-pdf.1080602/
        Will you please help me get the [2D63]LOGIC.bin file for my TV?
        05-17-2025, 02:47 PM
      • sikocan
        NP930XED Samsung Galaxy Book2 Pro Laptop PD Firmware Loop
        by sikocan
        I hope this message finds you well. I wanted to share a recent experience I had with a laptop that had a Type-C Port issue, specifically related to a PD (Power Delivery) controller problem. After replacing the damaged PD controller chip with a new one I purchased from AliExpress, the laptop now charges properly and negotiates power as expected, allowing the device to power up. I've replaced this chip twice just in case.
        However, it seems that the laptop's BIOS is detecting an older version of the PD Firmware on the newly installed chip. As a result, it attempts...
        01-11-2024, 01:47 AM
      • Robby-Gr
        TV Samsung UE55HU8500L (2014) – service menu + firmware reflashing advice needed
        by Robby-Gr
        I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality — very close to the original.
        However, since the swap, the TV enters a boot loop (Samsung logo → restart) unless I enter the service menu and perform a reset.
        The service mode had been previously modified — possibly by a technician or during the panel swap — and I suspect some key settings are mismatched for the European (Greece) market.
        Additional issues:...
        09-27-2025, 12:02 AM
      • Mirenia
        Samsung UEMU6199U - no Standby - bad Firmware?
        by Mirenia
        I've got a Samsung UEMU6199U which has no Standby LED and no reaction if try turning it on.
        Voltages on the power supply board is okay. Backlight test is also okay.
        I read about a corrupt firmware on IC1604 on some models, did a dump of this IC and turns out: First sectors are empty.
        So I think my TV has exactly this issue.
        Can someone please fix the dump?
        And how do you do that?
        As I understand you fill in the empty sectors and leave the rest as it is. But where do you get the "information" of what you...
        05-12-2025, 06:13 AM
