LCD back light
  • barry wilkins
    • Aug 2009
    • 172
    LCD back light
    I was looking at a small LCD on an instrument the other day ,on the RHS of the screen it was dark and difficult to see the characters.
    Is the the ccl that causes this fault ?
    Would a replacement tube fix this ?
    thanks
    Barry Wilkins
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: LCD back light
    Yes it could be a bad backlight bulb, or one that has significantly lost brightness. Could also be a bad led if the backlight is an led type.
    Muh-soggy-knee
      Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
      This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
      I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
      I am comparing them to a brand new one that I installed
      The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
      I going to let it run for several days before I remount back on the wall next to the...
      09-05-2024, 06:48 PM
    • PNI E.
      tcl u65x9006 back light on but no picture sounf ok after 40 50 secs
      by PNI E.
      hi guys, i need your help again...i have tcl u65x9006. while i was watching it become darker like when a movie ends, little by little the image disappear. now if i turn on i have back light on, after like 1 min i have also sound but no picuture. the back light is on i take off one at time the ldvs but nothing change always no picture. i tried to cover with a piece of paper the pin of ldvs i cover like 7 8 pins but nothing worked. the tv stay with no picture. there is a tcon board.i checked the voltage there on the fuse i have 11,8 volts. there is caps in shorts on the exit of the tcon i have...
      02-20-2025, 08:36 AM
    • jdawg99
      LG 47LA620V Same LED Failing Back Light Issues
      by jdawg99
      Hi All,
      I need some help with this one please. I am attempting a repair on the backlight. TV turns on and flashes the LG logo so stripped it down and found one faulty LED. Replaced it and tested on an LED tester and the strip was good. Put it back onto the PSU and it lasted about 20 seconds before going out again. Same LED had blown. Changed it for another type of SMD one (same voltage) and it seemed fine. Put the TV back together but it was quite dim. Noticed it was in power save mode so turned it off and the screen was bright. Left it on for half an hour only to come back to the...
      04-23-2023, 01:04 PM
    • boyebaran
      hisense 65k560 back light problem
      by boyebaran
      hi to all
      tv turn on and show logo(backlight on)than backlight turn off than red led in front blinking 7 time. the tv remote control working fine (sound on no picture).backlight changed same problem
      in 65k560 how to remove protection of backlight? picture of inverter and sockets attached .
      please advise me tnx
      05-20-2025, 07:11 AM
    • howardc64
      by howardc64
      Problem
      08-04-2024, 10:36 PM
