I have a ~1 year old monitor that has recently stopped working. When I press the power button there is no response from the monitor--screen stays black, LED light does not light, and there is no sound of any kind other than the "click" of the power button being depressed. There weren't any symptoms noticed leading up to the failure. This monitor has an external (brick) power supply which I tested on another monitor--worked fine. I've also ruled out ports on my video card and cabling between monitor and video card.
After some reading one thing I decided to check was the status of the capacitors inside the monitor. From research on this site it looks like the CapXon (green, on the small board in both photos) are possible culprits. These are labeled "220uF 35V" on one side and "P1142 Vent" on the other. These green capacitors appear to have a very very slight bulge which you may be able to see in the second photo, but I don't have any "good" CapXon to compare to. Does this look like a problem or am I seeing things?
None of the other capacitors on either board seem to have any sort of bulging or discharge so I didn't take any detail photos of them. The other capacitors are nicon/KME and the green capacitors on the other board are branded KSC.
