proview pv190wlcm
+ More Options
Posts
  • gasinmars
    • Apr 2013
    • 53
    • israel
    proview pv190wlcm
    hi guys i have an lcd computer , when i turn it on i recived a white color all the time , can someone guide me how to fix it
  • selldoor
    Slow Learner
    • 7870
    Re: proview pv190wlcm
    Welcome to the forum-
    We can help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back (in the same orientation) and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
    Examples of what is needed
    https://www.badcaps.net/forum/attach...7&d=1280167246
    https://www.badcaps.net/forum/attach...6&d=1280167246
    https://www.badcaps.net/forum/attach...4&d=1280167246
    It will be useful if you can say a bit about yourself - skills tools etc.
    • gasinmars
      • Apr 2013
      • 53
      • israel
      her it is
      • gasinmars
        • Apr 2013
        • 53
        • israel
        i have multimeter , solder iron , flux .
        • selldoor
          Slow Learner
          • 7870
          OK - Need bigger pictures of each board front and back and also the one attached to the panel.
          While you do that try taking off the LVDS cable (from the main( green) board to the panel clean and replace.
          • gasinmars
            • Apr 2013
            • 53
            • israel
            here are the pictures
            • selldoor
              Slow Learner
              • 7870
              Main board pic front is not really clear enough - you need better light - near a window or outside? In the last picture you show the board fixed to the panel. I need a clear picture
              of that board - take it in 3 sections to get it bigger.
              • gasinmars
                • Apr 2013
                • 53
                • israel
                pics
                • selldoor
                  Slow Learner
                  • 7870
                  Golly this is hard work! On the up side the pics are much better.- Thanks
                  When a screen is all white it is often due to a problem on the long thin board attached to the panel. The best way to get a picture is to take 3 - left centre right. You may need to fold the plastic back and sellotape it.
                  Did you clean and replace the LVDS cable and have you tried the minitor with a source (PC) attached
                  • gasinmars
                    • Apr 2013
                    • 53
                    • israel
                    yes i have been cleaned the lvds cable and still white screen ,even if i connect the lcd to the pc and not connected to the pc still white screen .
                    how to determine if the problem from power supply or logic board
                    • gasinmars
                      • Apr 2013
                      • 53
                      • israel
                      can anyone help me?
                      • selldoor
                        Slow Learner
                        • 7870
                        We are waiting for you to post pictures of the long thin board.
                        • gasinmars
                          • Apr 2013
                          • 53
                          • israel
                          you want pic logic board or power suplly?
                          • gasinmars
                            • Apr 2013
                            • 53
                            • israel
                            logic board
                            • selldoor
                              Slow Learner
                              • 7870
                              The long thin board outlined in red in post 9
                              • gasinmars
                                • Apr 2013
                                • 53
                                • israel
                                okay know iam understand , do you think that's the problem ?
                                look from what iam thinking the problem is from the powersupply because when i mesure 13 v pin, it will show on the multimeter 0 volt
                                • Behemot
                                  • 4845
                                  • CZ
                                  You DO measure the voltage against ground, right? I don't think PSU is bad anyway, you won't get anything without it. Obviously backlight works otherwise it would be black so problem is either logic board or the display's board.
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4289
                                    • Italy - Milan
                                    Instead of making pictures you can first search for a little white smd fuse on the panel's board (the long one), it is often marked as F1 or F2 and test it, the reason that you doesn't measure those 14v (not 13) is that there isn't the jumper jp206 and is normal by the factory, the panels runs at 5v usually, somethimes at 12v, maybe in other sub models there's the need of the 14v line to the main board (for the panel probably)
