samsung 245bw blank screen, pop then no power.
  • b6echufr
    • Mar 2013
    • 12
    Re: samsung 245bw blank screen, pop then no power.
    I purchased a hakko 888 today with some tips. Hopefully that will help when I get to the point of removing components to test.
    I'm going to pick up some alcohol today to assist in removing the glue. I need Denatured, not Isopropyl correct?
    I looked at the BN44-00173A and the price is cheap enough for me. My concern is ordering from China. I'm sure it means I have no recourse if it is defective in some way. The listing does say they are new. Is the 173A a better choice over the 195A?
    • euromatlox
      • Mar 2013
      • 60
      • Finland
      '173A' is usually easier to fix, '195A' might easily require dealing with some SMD components. If compared, the heatsinks are also bigger on '173A'. The specs on board tell that 5.3v line can provide 0.5A more current.
      The board in the picture in eBay has original '3 resistors' and caps. I would change them before installing that board. Caps (minimum replacement) are 470uF/35v, 2200uF/10v, 2x1000uF/10v and resistors 3pcs 68ohm 1W. I have replaced the caps with 470uF/35v and 3x3300uF/6.3v good quality motherboard caps and resistors 3pcs 68ohm 2W. Of course usually replacing with lower voltage caps is not wise, but in this case voltage is 5.3V so 6.3v caps are okay.
      • b6echufr
        • Mar 2013
        • 12
        Just to update. After far to many hours I was able to remove the glue. some of the edges were brown and I understand that means it was becoming conductive. I'm sure some components were ruined in the removal process. I am now making a parts list of what I need to buy and replace to start. The red resisters and of course the blown blue one. Maybe one or 3 diodes just to be safe. I guess I should order some MOSFETs too as a couple are near the blown resister. the only damage I can see top or bottom is that one blue resister that was blackened.
        Is there any particular brand I should be using or style? I was just going to read the color codes and get whatever ohm resistance it is. Same with any diodes or MOSFETs. The caps all look good. Should I replace all of them as well?
        • euromatlox
          • Mar 2013
          • 60
          • Finland
          The three electrolyte caps at 5.3v side (near 8008hfe regulator and a big coil) should be 'always' replaced. Very common parts to fail. You may use slightly bigger caps, see my earlier post.
          • mrtek
            Samsung UN65js8500F, no sound, blank screen and T-Con board with one LED on
            by mrtek
            Hi I am new to this kind of repairs but I want to learn..I have a Samsung UN65JS8500F. the TV used to work and I tried to fix darker areas in the middle only ( img 1,2,3). I thought the led strip were bad..not the case. I did not research in advance what kind and where the LED were located. In this model they are located vertically on right and left side. Took the TV apart and put it back together. Now the tv shows no welcome screen and no sound is available thru the speakers. ..just a black screen..Backlight LED do turn on...also noticed a 5 blink code , not sure if that was there before. I can...
            11-26-2024, 09:58 AM
          • Chrissygizmo
            by Chrissygizmo
            02-10-2025, 12:33 AM
          • Chrissygizmo
            samsung galaxy ao2s very temperamental after screen replaced
            by Chrissygizmo
            Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
            Ive eventually managed to get it on and working but it's very temperamental...
            The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
            05-26-2024, 12:05 AM
          • Kiberge
            Samsung LH82QENELGC/EN Help needed - Static line on screen
            by Kiberge
            HI guys!
            I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
            I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
            the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
            This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
            04-22-2024, 11:28 AM
          • Ryan.man
            by Ryan.man
            02-04-2025, 12:23 PM
