Samsung 932MW - Fades to black
  • JoeyJoe
    • Sep 2012
    • 76
    • United Kingdom
    I have another monitor which is a 19" HDTV / Monitor that has the fade to black after 2 seconds symptoms.
    Caps all look fine, but can someone tell me if my inverter readings are ok?
    D - C = 1198 ohm
    B - A = 956 ohm
    H - G = 0 ohm
    F - E = 618 ohm
    I'm not 100% sure I know which is primary or secondary.
    Is this enough info to determine if the transformer is working correctly?
    Joe
  • selldoor
    Slow Learner
    • 7870
    Re: Samsung 932MW - Fades to black
    Secondary are A to B and C to D
    so they do not look good - Some of the solder doesnt look great
    and it will need reflowing. Fortunately these are available
    so I suggest you remove carefully from the board and re- test.
    EDIT -- should be approx 1.2kohms on both so they are well outside the 3% rule but worth testing off board in case of outside influences.
    • JoeyJoe
      • Sep 2012
      • 76
      • United Kingdom
      Thanks, I will re-flow the solder now and test again.
      Found replacement inverter for £4.90 on eBay with free shipping so hopefully an easy fix!
      I have another 22" monitor with a faulty inverter, I couldn't find the same inverter anywhere, Would using one of these ones be fine?
      • selldoor
        Slow Learner
        • 7870
        No - at least very unlikely. what is its number or the board number its on.
        • JoeyJoe
          • Sep 2012
          • 76
          • United Kingdom
          PLLM-M702A is the board from the 22" screen.
          I have reflowed the solder but problem is still happening, I will remove the inverter from the board now.
          • JoeyJoe
            • Sep 2012
            • 76
            • United Kingdom
            I removed the inverter, and have retested. I didn't have a solder sucker neither any solder wick, I removed it by slowly prying it off while heating up the terminals.
            A - B = 1145ohm
            C - D = 1247ohm
            E - F = Nothing (just said 1 on the meter)
            G - H = Nothing
            • euromatlox
              • Mar 2013
              • 60
              • Finland
              When you solder that part back (or replacement), change also those smaller electrolyte capacitors. It is not a big cost. Lack of visible failure signs (leaks) is not guarantee. Huge cap is probably okay, but at some point that can be also checked/changed (it's more costly).
              • selldoor
                Slow Learner
                • 7870
                I dont think there is much point soldering it back its around 8-9% adrift.
                • JoeyJoe
                  • Sep 2012
                  • 76
                  • United Kingdom
                  I will replace both the transformer and the electrolyte caps. Thanks for your help.
                  I have around 6 monitors I can use for spares that might have a suitable capacitor
                  • bbjunkie
                    • Dec 2011
                    • 301
                    Hi JoeyJoe, did this fix your problem? I have a similar issue with same model - already replaced inverter transformer due to out of spec readings.
                      09-07-2024, 05:50 AM
                      09-06-2024, 11:40 PM
                      09-06-2024, 08:40 PM
                      Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook Specification for Upgrade or Repair
                      This specification for the Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-X01DE boardview and NP950XCJ-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                      09-06-2024, 06:20 PM
