Xerox XA7-19i - Need help identifying component.
  • leapius
    • Aug 2012
    • 60
    Hi everyone, I have a Xerox XA7-19i with a 2 seconds to black problem.
    On visual inspection of the PSU board I found 1 x 470uF 25v cap to be blown and one other component on the underside of the board to be blown as can be seen in the photographs.
    It is labelled: 4606 BD4358
    It is in position U101 as can be seen.
    What kind of component is this? A transistor? It will probably be hard finding a direct replacement with the same label but maybe I can replace it with one of the same likeness? Is there any way I can check what it is using a multimeter on one the other ones (in U102,U204,U105).
    I was going to do a full re-cap but I need to find out what this compnent is and what I can replace it with. I am an amateur but have decent soldering skills and patience. Can anyone help me find a replacement for this component?
    Many thanks in advance,
    Leo
  • Rtech
    • Jul 2010
    • 1095
    Re: Xerox XA7-19i - Need help identifying component.
    It is AO4606 as below,they are available...
    http://pdf1.alldatasheet.com/datashe...MD/AO4606.html
    • leapius
      • Aug 2012
      • 60
      That's great! Thank you loads for the information. Going to go shopping and I will report back..
